2000 F-150 GEM Module location
Does anyone know where exactly the GEM Module is located on my 2000 f150? I need to replace it but have conflicting info on the location. Someone told me it was behind the instument panel and another said behind the fuse box...
Any info would be greatly appreciated.
Thanks!
Thanks!
Hello,
Thanks for all your info. I brought my truck to my local Ford dealer because the drivers side power window stopped working, the passenger window will only work intermittenly as well. The Ford Tech told me they did a scan and found the GEM Module was bad, they too also said it was most likely cause by a water leak. They told me its going to cost between $300 and $325 to fix it with labor. I have connections with another Ford garage thats out of state that ill be getting the parts from. My cost is going to be about $110. It soundslike a big job, anyone attempt this yet? When I get done with my repairs ill let you all know how it went.
Thanks again.
Thanks again.
