best carbed 4 cylinder for ranger?
what is the best carbed 4 cylinder to build for a 2wd ranger?
does the 2.0 or 2.3 have the most aftermarket support?
does any 4 cylinder have the same bellhousing pattern as the 2.8 V6
I'm kind of thinking about eventually putting together a mildy
built 4 cylinder, but I don't really have a starting point.
Well
I dont know of any one as "best" in factory form they are all close.Prolly within 10 HP of each other in stock trim.I do think as said before that a larger than stock cam port polish and shave to 9.0 CR is all good.And also as posted try to make it all flow headers cat removal if you can in your area.If you have a carb set up already you have a AIR or smog pump.Get rid of it if you can.
94_Ford_Ranger
1983 - 2012 Ranger & B-Series
10-02-2015 09:57 PM
