Windstar van won't idle
I've got a 2000 Ford Windstar w/ 3.8L V6 and Auto tranny, 104K miles. When starting, it'll crank and fire, but won't idle itself, therefore shutting off. I can keep it held @ 800RPM w/ the gas pedal, but when I let off, it dies again. I just changed the air filter, so that isn't the problem. When raising the revs with the gas pedal, it's smooth, so I don't suspect the plugs to be fouled, even though they're due to be changed (original plugs).
This will be my first major repair, so I don't even have the shop manual yet. Should I get the Haynes or is there a better one?
Thanks in advance!
Thanks in advance!
3 words: Idle Air Control
Not familiar with windstars, but it's a valve on the throttle body that contols the idle speed. When it goes bad, that is the classic symptom: vehicle will not idle unless your foot is on the pedal. Then again, I could be wrong, it's been know to happen from time to time......but check that first.
Hello, I also have a 2000 windstar mine had 93,000 other the a powersteering pump I have only done routine maintenance. Anyway while reading your thread I happen to have my Hayes Manuel sitting right next to me and here is what the troubleshooting says.
section7 "Engine starts but stops immediately"
1. loose or damaged wire harness connections at distributor, coil or alternator.
2. Intake manifold vacuum leaks. Make sure all mounting bolts\nuts are tight and all vacuum hoses connected to the manifold are attached properly and in good condition.
3.Insufficient fuel pressure (see Chapter 4).
4. Fuel injection or engine control systems malfunction (chapters 4 and 6).
paul
Haynes North America, inc. 1998, 2001
Ford windstar 1995 trou 2001
Haynes Repair Manual (pg.0-21)
paul
WOW!! I didn't think I'd have so many responses from just one night. I'm impressed, guys!
I picked up a shop manual today during lunch, so tonight I'll be checking the IAC, along with any vacuum lines. The fuel filter is probably due to be changed, as well, so I'll look into that one, too.
Thanks, again!
Thanks, again!
UPDATE:
When I got home, I jumped straight on the IAC, following the test procedures in the Haynes Manual I picked up. The electrical readings were all w/in specs, so I popped it off the throttle body. Sure enough, it was pretty well carbonated. So, I did my best to wipe it off, manually operated the valve, and reinstalled it. Works great! Thanks for your help!
the5schlueters
08-30-2016 09:22 PM
78bigunns
General Automotive Discussion
03-07-2010 05:56 PM
