Minnesota Chapter Join Chapter, Leader: fordpower88
how hard is it to change the ignition switch
Old 10-21-2004, 09:38 AM
ford_f100_custom's Avatar
ford_f100_custom
ford_f100_custom is offline
i dont know if this is whats wrong but i turn my key and its kind of hard to turn like it needs oiled but i dont know what will fix it .i tried new keys and that didnt do it do any ideas? tx brooklyn park mn
Old 10-21-2004, 07:11 PM
mustanghd's Avatar
mustanghd
mustanghd is offline
Ignition switch
I;m not sure if the truck is like my mustang but the ign. switch should have a little hole in it if you put the key in the switch and turn it to the on postion then put a paper clip in the hole and turn the key back the whole key assembly will pull out then you can oil it with a light oil such as oil for a fishing reel or sewing machine I hope this helps
Old 10-22-2004, 11:21 AM
rick90yj's Avatar
rick90yj
rick90yj is offline
what year is this truck? Is the switch in the column or the dash? The above description is correct for a column switch. Dash switch should unscrew from the back and after you unplug it, it slides out towards the seat. I'm not real sure without knowing the year.
RBerry9511
02-07-2020 04:31 PM
Jklnhyd
03-14-2014 10:27 PM
WD4B
21
04-07-2012 11:41 AM
54Guy
1978 - 1996 Big Bronco
03-25-2007 10:51 PM
nickh
01-24-2007 08:53 AM
Quick Reply: how hard is it to change the ignition switch
