1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
1999 Ranger heater core replacement
Old 10-20-2004, 11:40 AM
Mavric's Avatar
Mavric
Mavric is offline
Hey guys,
I am sure this has been asked before but the search engine is down and I need to know what it is going to take to replace the heater core in my 1999 Ranger SuperCab 4x4. It does have A/C. I use to turn wrenches for a living but do not have a GOOD current repair manual such as a Mitchell Manual with an ac/heat section. Any help is greatly appreciated. Thx.
Old 10-20-2004, 12:38 PM
mattmcl's Avatar
mattmcl
mattmcl is offline
From the factory service manual CD:
Heater Core
Removal
Note:
If a heater core leak is suspected, the heater core must be leak tested before it is removed from the vehicle. For additional information, refer to «Section 412-00».
1. Remove the instrument panel. For additional information, refer to «Section 501-12».
2. Remove the evaporator core housing. For additional information, refer to «Evaporator Core Housing» in this section.
3. Drain the radiator. For additional information, refer to «Section 303-03».
µ 4. Disconnect the heater hoses from the heater core (18476).
µ 5. Remove the nuts and the plenum chamber.
µ 6. Remove the screws and remove the heater core cover.
µ 7. Remove the heater core.
Installation
1. Note:
Be sure to install a new oval foam seal around the heater core inlet and outlet tubes.
To install, reverse the removal procedure.
l Lubricate the hoses and fittings with Ford Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A.
Old 10-20-2004, 12:40 PM
mattmcl's Avatar
mattmcl
mattmcl is offline
Here is the section it refers to:
Removal
1. Disconnect the battery ground cable (14301). For additional information, refer to «Section 414-01».
2. Recover the refrigerant. For additional information, refer to «Section 412-00».
3. Remove the engine air cleaner (ACL) (9600). For additional information, refer to «Section 303-12».
µ 4. Remove the nuts and the screws from the windshield washer reservoir/coolant recovery reservoir and reposition the reservoir.
µ 5. Remove the screws and reposition the A/C vacuum reservoir tank and bracket (19A566).
µ 6. Disconnect the connector from the speed control servo (9C735).
µ 7. Remove the screw and reposition the speed control servo.
µ 8. Disconnect the A/C manifold and tube (19D734) from the suction accumulator/drier (19C836). For additional information, refer to the Spring Lock Couplings Disconnect and Connect general procedure in «Section 412-00».
µ 9. Disconnect the condenser to evaporator tube (19835) from the A/C evaporator core (19860). For additional information, refer to the Spring Lock Couplings Disconnect and Connect general procedure in «Section 412-00».
µ 10. Disconnect the electrical connector from the A/C cycling switch (19E561).
µ 11. Disconnect the electrical connector from the blower motor (18527).
µ 12. Disconnect the electrical connector from the heater blower motor switch resistor (18591).
µ 13. Remove the support bracket (3.0L and 4.0L engines).
µ 14. Disengage the windshield washer hose retainer and position aside.
µ 15. Disconnect the vacuum hose.
µ 16. Disconnect the vacuum hose from the retainer and position aside.
µ 17. Remove the A/C hose support retaining bolts from the back of the engine (4.0L only).
µ 18. Disconnect the vacuum harness connector located in the passenger compartment.
µ 19. Remove the nut located in the passenger compartment.
µ 20. Remove the nuts and remove the evaporator core housing.
Installation
1. Install the evaporator core housing and retaining nuts.
2. Install the retaining nut in the passenger compartment.
µ 3. Connect the vacuum harness connector in the passenger compartment.
µ 4. Install the A/C hose support retaining bolts to the back of the engine (4.0L only).
µ 5. Install the vacuum hose into the retainer.
µ 6. Connect the vacuum hose to the water diverter valve.
µ 7. Install the windshield washer hose retainer.
µ 8. Install the support bracket on 3.0L and 4.0L engines only.
µ 9. Connect the electrical connectors to the blower motor and the heater blower motor switch resistor.
µ 10. Connect the electrical connector to the A/C cycling switch.
µ 11. Note:
New green O-ring seals should be lubricated with PAG Compressor Oil, YN-12-C (F7AZ-19589-DA) or equivalent meeting Ford specification WSH-M1C231-B. Use of sharp tools should be avoided.
Connect the condenser to evaporator tube to the A/C evaporator core. For additional information, refer to the Spring Lock Coupling Disconnect and Connect general procedure in «Section 412-00».
µ 12. Connect the A/C manifold and tube to the suction accumulator/drier. For additional information, refer to the Spring Lock Coupling Disconnect and Connect general procedure in «Section 412-00».
µ 13. Install the speed control servo and connect the electrical connector.
µ 14. Install the A/C vacuum reservoir tank and bracket.
µ 15. Install the windshield washer reservoir/coolant recovery reservoir.
16. Install the engine air cleaner. For additional information, refer to «Section 303-12».
17. Connect the battery ground cable.
18. Evacuate and charge the refrigerant system. For additional information, refer to «Section 412-00».
fordiesel69
1999 to 2016 Super Duty
11-10-2013 07:49 AM
Danspeed1
1997 - 2003 F150
24
07-20-2012 11:54 AM
roushboy
05-18-2011 01:59 PM
flo21i99
11-05-2006 02:06 PM
ledbetter
06-25-2005 01:35 PM
Quick Reply: 1999 Ranger heater core replacement
