Looking for someone that knows what to look for when checking rear bearings on big bronco or 1/2 ton . how much lateral movement of axle is allowed? up and down movement? etc. also what is the quick way of adjusting power steering box? thanks
For the bearings there should be mimal to no movement and if there was this would indicate wear problems, as for the steering i wouldn't be able to tell you but if you go and check in the forum that your truck is located in you should be able to get somehelp on that one.
