West Virginia Chapter Join Chapter, Leader: 5_labsownus
Explorer 96
Old 10-09-2004, 08:57 AM
Hillbilly48's Avatar
Hillbilly48
Hillbilly48 is offline
Explorer 96
My wipers, door locks and domelights are going out intermitently, sometimes for days then come back. Any suggestions?
Old 10-11-2004, 04:20 AM
fitter565's Avatar
fitter565
fitter565 is offline
Hillbilly48, Welcome to the WV chapter! I would look for a loose ground. Then I would trace down each wire looking for broken or bare wires. I'm sure someone will chime in soon with some other idea's.
Mike
Old 10-11-2004, 10:48 AM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
Received 1,522 Likes on 1,420 Posts
You may need to get into the dash. Most trucks have the wiring harness for all options and the pigtails for the options are not installed on vehicles that do not have them (electric door locks). The plug where the pigtail and harness meet may not be together good! I have had this happen before even with the locking type plugs. Also you may need to pull the plugs apart and make sure the pins are push into the plug and lock in place. All of the non-water proof plugs (mostly under the dash) have removable/replaceable pins. Some times the pins will push out when the plug is put together.
If this is not the case I would look at the ground as Mike said.
If the Dome lights are electronic controled i.e. auto shut off, auto dim, or turn off when engine is started. The control module may be bad or loose. Many times these modules control many systems and could include the wipers, lights and other alarms!
