1962 Ford F-602 Timing
Old 10-06-2004, 09:53 AM
Sam Smanko's Avatar
Sam Smanko
Sam Smanko is offline
Does anyone know the timing of a "Q" engine. I think it is a engine; or if not, do you know if it is covered in the sevice manual? That is to ask, is it worth my spending $75 to buy a manual only to find that it either is not in the manual or that it is something that someone here can tell me? Tks.
Old 10-06-2004, 10:36 AM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
I'm going to guess you have a 292. A V-8 where the driver side exhaust comes out the front and crosses to the passenger side manifold?
I'm going to guess again. Try 6 degrees btdc. Regular fuel 289's & FE's were at 6 degrees, so I'm guessing Ford liked that number. You might be able to run up to 10, but start at 6 and see how it runs.
Still have points? .16 I think. Am I right? Is my memory still there?
Better minds may chime in.
ID that motor and try the motor specific threads if you have no luck.
Old 10-06-2004, 05:18 PM
mantta's Avatar
mantta
mantta is offline
That engine could also be a 330 or a 361.
Old 10-06-2004, 07:39 PM
Kenny's Avatar
Kenny
Kenny is offline
Hi Sam,
Engine code "Q" would be the 477 Super duty V-8 engine.
According to my '59 Truck shop manual...............
"Initial Ignition Timing (B.T.D.C.)"
"All HD and SD V-8 (302,332,401,477,534)
With regular fuel of 85-88 octane..........................................4 Deg.
With regular fuel of 88-90 octane..........................................6 Deg.
With regular fuel of 90-92 octane..........................................8 Deg.
With regular fuel of 92 octane or more, or premium fuel............10 Deg."
I hope this helps.
stloupster
50
07-25-2022 03:13 AM
DedmonDuppy
13
09-25-2019 02:11 PM
elroy6468
03-28-2015 11:55 PM
texastech_diesel
1999 to 2016 Super Duty
283
03-26-2015 12:18 PM
Quick Reply: 1962 Ford F-602 Timing
