Michigan Chapter Join Chapter, Leader: Toyman
Ever seen a pinion go through the housing of a Dana 60?... I have!
Old 09-21-2004, 10:49 PM
16secondP71's Avatar
16secondP71
16secondP71 is offline
Well,, I went up to Silver Lake for the last time this year and manged to destroy the front axle in my SD. I launched it over a hill and when the front wheels hit the ground, the driveshaft spun the pinon into two pieces. The worst part is that the ring gear grabbed the broken pinon and pushed it through the top of the diff housing... Can that be welded???
I figure if I can find a weld shop that can weld cast then I can throw a new set of gears in it and have it fixed. Otherwise, I'm off to the late model bone yard in search of a front axle.
Old 09-27-2004, 07:47 AM
jalampi's Avatar
jalampi
jalampi is offline
got any pictures?
Old 09-27-2004, 06:41 PM
16secondP71
NOPE... and probably never will.
Amphihauler
16
09-08-2017 08:07 PM
steveg5.0
04-28-2015 09:16 PM
Fordpk52
23
09-26-2012 12:40 AM
wasowski
08-30-2011 06:10 PM
roundman 50
11-26-2010 09:24 AM
Quick Reply: Ever seen a pinion go through the housing of a Dana 60?... I have!
