EGR Disconnect Instructions
Old 06-24-2004, 11:07 PM
SpartanDieselTech's Avatar
SpartanDieselTech
SpartanDieselTech is offline
Former Vendor
This issue has been a hot discussion topic for several weeks now.
For everyone’s reference and use, I am going to list step by step instructions on the disconnection of the EGR system and removal of the EGR backpressure throttle plate (this throttle plate is only present in early 03 builds, and all 2004 builds; This is in reference to the ENGINE build date, not the trucks; if this does not apply to you simply skip over it and disconnect the EGR only)
First off, I will enlighten everyone (those of you who have not been keeping up with this discussion) with the pros and cons of this procedure. There have been many, many threads on this; please go back and read through these if you wish to uncover the details of the subject. Here are a couple of the more recent threads…
http://www.fordtrucks.com/forums/sho...d.php?t=254050
http://www.fordtrucks.com/forums/sho...d.php?t=240135
Here are two earlier posts I made about its effects on my motor-
Originally Posted by PSD 60L Fx4
Since you have a 550, I will assume you will doing a large amout of towing. If I may, I would advise you to unplug the EGR valve on your motor. The valve is located directly in between the large black cylindrical oil filter and 90 degree aluminum intake elbow/throttle body on top of the motor. It is a small black cylinder directly on top with a 4 prong wire harness connector going directly into the top. Just pull the plug. This issue has been debated quite a bit on this site; some will tell you it helps performance and mileage, and some will disagree. This is my experience, good and bad.
Upon disconnection, I noticed a small to medium decrease in the turbo spool time (ie, less lag) under partial throttle, lower rpm conditions. This modification will not affect the motor at higher rpm's under heavy load, as the motor lacks the backpressure to trigger exhaust gas recirculation under these conditions.
The reason for the partial throttle enhancement is this - the EGR valve pulls exhaust gasses out of the passenger side uppipe and recirculates the gasses back into the intake to reduce engine emissions. This has a negative impact on power in two ways. First, the exhaust air is much hotter than the air from the compressor side of the turbo after it is intercooled. The EGR system has a cooler on it, but from all literature i have read the gasses from it are still an average of 150 to 200 degrees hotter. Hot intake gasses negatively impact performance. Foremostly, however, is the fact that the gasses are drawn from the uppipe. The lost quantity of gas is that of which COULD be spooling the turbo; therefore by disabling the valve, 100% of the exhaust air is being put through the turbocharger, thereby reducing the time it takes to spool up.
Do not expect any miracles from this, however IMO it is worth the total of 10-15 seconds it takes to pull the plug on it. Doing so will generate two Diagnostic Trouble Codes in the PCM - P0400 (Exhaust Gas Recirculation Flow Error) and P0407 (Exhaust Gas Recirculation Sensor A Circuit Low). Neither of these codes will trigger the check engine light, and can easily be cleared with a tuner, scanner, or by simply unplugging the battery. As for gas mileage, I really have not calculated, but the overhead lie-o-meter seems to have shown about a half mile to the gallon gain.
In reference to this post, check out this link
http://www.backglass.org/duncan/ps60...l/ps60_031.jpg
You can see in the illustration how air is extracted from the passenger side upipe the EGR before it reaches the turbocharger.
I have driven about 3000 miles with it unhooked now. According to the 6.0 Bible, the default position for the valve is closed. Therefore, when the engine is shut off, the valve will be closed. Unplug the valve with the engine off and it will not open again until it is plugged back in. Alot of people I have talked to notice very little or no performance gain from it; I apparently was a lucky one and experienced a middle-of the road gain. I suppose its just worth a try; if you try it and dont think its worth it, it is very easy to put back the way it was. As for the engine running cleaner, I have noticed that there is very little or no oil in the boost tubes or intake elbow after unplugging it.
Here is a quote pulled from FredsF250TD in another thread…
Originally Posted by FredsF250TD
I just bought my wife a new VW Passat 1.9 TDI last Saturday. While trying to track down the 5w40, VW 505.01 spec synthetic oil VW says HAS to be used in this motor, I ran across a website that has a EGR bypass kit for the TDI. They had pictures of the amount of soot that builds up in the intake and the EGR. I mean these things were AT LEAST 3/4 clogged compared to the pics of a clean intake. They did not say how many miles it took to do this, but frankly I don't care. It was a mess, and they said it was all due to the EGR. I know, we are talking two different engines here, but they are both diesels with EGR systems.
On most 03’s you will not receive a performance gain, as mentioned earlier. However, in all build dates, by disconnecting the EGR, you will clean up your intake air by preventing the recirculation of engine carbon, ect. Theoretically this will increase the life of both your oil and engine.
Before beginning the removal procedure, please check out this link to the 6.0 Bible.
http://www.backglass.org/duncan/ps60_manual/
Consult these three pages
1. http://www.backglass.org/duncan/ps60...l/ps60_009.jpg
2. http://www.backglass.org/duncan/ps60...l/ps60_038.jpg
3. http://www.backglass.org/duncan/ps60...l/ps60_037.jpg
The EGR is located on a small black cylinder (the black cylinder is the valve itself) right between the oil filter housing and intake elbow on top of the motor-just pull the plug. If you cannot find the location of it, first check the links above. Second – under the hood of the vehicle, look direcly to the center of the top of the motor. You will see a large black cylinder sticking out of the top of the motor; it is the largest object front-side of the turbocharger. Direcly in front of it will be a smaller black cylinder, with a 4-wire weatherpack connector on top. Reach down, pull the tab on the backside of the plug, and remove it. This will disconnect the EGR valve. (Ensure that the switch to the vehicle is off before pulling it, the vehicle must be off to ensure the valve is closed. Otherwise, it is possible to lock it in the open position.)
The throttle plate is a slightly more involved process to remove. REMEMBER, this is not necessary for later 03 build dates; once you get the elbow off there will be no plate. However, for anyone with a set of sockets, it is simple. Here are the tools you will need – a 3/8 drive ratchet, a 3/8 extension bar (preferably a fairly long one), an 8mm socket, a 10mm socket, and either a 9mm socket or a flathead screwdriver, depending on the build date of the engine. To begin – remove the clamp holding the boost tube to the engine. The boost tube comes up from the bottom of the right side of the front of the motor, over top the motor, and into the elbow. The clamp will either be located on a piece of flexible rubber hose (03 build) or on a rigid black plastic pipe (04 build). For 03 build, there will be two clamps, remove the one closest to the aluminum elbow. Remove these and slide the boost tube over out of the way.
The elbow will have 4 bolts holding it onto the throttle body assembly. Three are 8mm; the front left side bolt is a longer, 10mm bolt. Remove these, and pull the intake off. In either the groove on the bottom side of the intake or the top side of the throttle assembly, there will be a large rubber o-ring. If possible, leave this ring in one of the grooves. If not, lay it to the side and DO NOT LOSE IT. When looking into the throttle assembly, you should see a large butterfly valve mounted in the throttle assembly. (ONCE AGAIN, if you do not, you have a late 03 build; begin the reassembly process) On both the right and left hand side of the throttle assembly you will see black boxes with wires leading into them; the left hand side is the throttle body servo motor, the right hand side is the throttle plate position sensor. It is not necessary to do anything to these.
To remove the plate, you will need a #10 torx driver. There are two small torx screws holding the plate to the throttle plate mounting crossbar. Rotate the plate to the SHUT position and loosen these screws. Before removing the screws totally, ensure that you have a magnet to pick them up with. YOU MUST NOT DROP THE SCREWS INTO THE INTAKE. Remove the screws with the magnet. Rotate the plate back to the open position, and pull the plate straight up to remove it.
For reassembly, start with the rubber o-ring between the throttle body and the intake elbow. If the motor was hot when you removed the o-ring, soak it in water for 30 seconds to cool it down; as if it is hot it will not properly fit back into the slot. Be sure the o-ring is properly seated and place the intake elbow back on top of the throttle body, ensuring that the holes are lined up. The larger of the 4 bolts goes back into the bottom left hand side. Retighten. Then, slip the boost tube back over the lip on the intake elbow. Retighten the clamp holding the tube on, and ensure that it is quite snug, BUT DO NOT STRIP IT OUT. If you have an 04 motor, do not slide the plastic tube all the way back to the end of the lip of the elbow. Slide it most of the way and snug it up lightly; wiggle it until it seats and then fully tighten. Start the motor and ensure that you cannot hear any air noises, ect. Presto.
If anyone would like further information on effects of the EGR, or the removal, feel free to email me or send a private message. I will provide any knowledge/knowhow I have on the subject.
Old 06-25-2004, 05:57 AM
SBV45's Avatar
SBV45
SBV45 is offline
That was worth cut & paste to word processor and saving. Thanks.
Old 06-25-2004, 07:32 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
This thread is a sticky because of the constant curiosity about this issue. We have many questions that continually re-surface, most like oil and a few others I will never stick, this one however deserves its time at the top. IT is my hope that when ANYONE in ANY thread ask about the EGR disconnect, PLEASE direct them to this………..it will save FTE space…. We all have spent time and countless posts replying to this question…………..time after time.
This is a great thread.
Old 06-25-2004, 11:17 AM
Diesel Cruiser's Avatar
Diesel Cruiser
Diesel Cruiser is offline
I have a VW '01 TDI so I'm aware of what EGR gasses do to a diesel. I pulled the plug on my 6.0 PSD quite awhile ago for that reason. It didn't do much for MPG or driveability, but the benefit should be in about 40-50,000 miles. My question is, why pull the throttle plate, what is it hurting?
Old 06-25-2004, 11:21 AM
SpartanDieselTech
Former Vendor
The throttle plate provides backpressure for the EGR. When the computer opens the EGR valve (assuming the truck has the throttle plate present, mostly 04's) The plate closes at a rate proportional to the amount of EGR flow commanded by the computer. By closing it, backpressure is created and the flow from the EGR is increased as the engine has to draw air from somewhere. This is simply an obstruction to airflow, and is useless when the EGR is disconnected.
Old 06-25-2004, 11:53 AM
Choctaw Bob's Avatar
Choctaw Bob
Choctaw Bob is offline
You did a really good job on this! Are you thinking a Mechanical Engineering Major?
Old 06-25-2004, 12:49 PM
JON CARLINE's Avatar
JON CARLINE
JON CARLINE is offline
Throttle Plate
I Don't Understand Why The Throttle Plate Was Removed In Later 03 Models Then Reinstalled On 04 Models?
Old 06-25-2004, 01:28 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
he better be, we are going to send him there weather he likes it or not
or aerospace
We need to keep this quiet Bob, I think we found a keeper.
Old 06-25-2004, 01:36 PM
SBV45's Avatar
SBV45
SBV45 is offline
I pulled my EGR this morning before I started the engine. When I went to lunch with two other guys, one of them said, "Did you slip a gas engine in this thing overnight? It is so much quiteter." I thought it was too, but had ruled it out as wishful thinking. It itdles smoother too!
Old 06-25-2004, 02:13 PM
SpartanDieselTech
Former Vendor
I *hopefully* will get into Georgia Tech. If I do, it will either be that or a similar field.
Old 06-25-2004, 02:14 PM
SpartanDieselTech
Former Vendor
We dont really know...
Old 06-25-2004, 02:52 PM
FredsF250TD's Avatar
FredsF250TD
FredsF250TD is offline
Nice job PSD. Very informative. Something dangerous however is happening, I'm brainstorming. Well, more like a light shower, but anyway. If JUST the throttle plate was removed but the EGR was left plugged in, would the EGR still function? I guess I'm kinda answering my own question here because I'm seeing the throttle plates function as being to supply sufficient back pressure for EGR operation but only in low power settings. Am I correct in this? If this is the case, than just removing the throttle plate would not prevent the EGR from operating at higher power setting. I was just trying to come up with a way to prevent the codes.
Old 06-25-2004, 03:13 PM
SpartanDieselTech
Former Vendor
Thats a good question....Common sense would say yes, but there are a tremendous amout of trucks that have no throttle plate from the factory. If that is the case, do the EGR's on these trucks actually work? It is something to ponder and research...
Im gonna try to work on this sort of stuff whenever i get a secondary motor in my truck. I will have an 04 stock motor i can set up in my garage to play with; i believe i can mount it with a fuel cell and with some extra parts off maybe a wrecked truck get it to run. If i can do that, there are all sorts of neat stuff you could do with the running motor sitting by itself This subject being one of them.
Old 06-25-2004, 03:24 PM
SpartanDieselTech
Former Vendor
Any check engine light? If you get a chance, pull the codes and see if you got the same two that I did. I think if we all get to work on this, we can totally kill the codes.
Old 06-25-2004, 03:41 PM
FredsF250TD
Don't have much time but one more thing to think about, the PCV gasses. These, mixed with the exhaust gasses from the EGR is what causes the mess in the TDI's intakes. What about venting the PCV gasses into a catch can instead of into the intake? I'm assuming our motors vent crankcase gasses into the intakes?
Quick Reply: EGR Disconnect Instructions
