tilt steering column
Old 09-06-2004, 08:15 PM
65 chero's Avatar
65 chero
65 chero is offline
Smile tilt steering column
Has anyone had experience in installing a tilt steering column in a 65 rancehero? If so, what make column did you use? Any helpful hints would really be appreciated.
Old 09-17-2004, 10:49 AM
rodbender's Avatar
rodbender
rodbender is offline
You might look at what the Mustang guys are doing. I have a 65 and I recall a tilt being put in one. You'll look at a 68 and later box as the 67 and earlier have the long shaft as your Ranchero/Falcon has. This will help you get started. Good Luck
Old 09-19-2004, 08:33 PM
Roger Carter's Avatar
Roger Carter
Roger Carter is offline
Ditto Rodbender's comments. Did this swap a few times many years ago. Not a nut and bolt, but pretty close. I understand some of the street rod parts suppliers have pieces that work, like Flaming River and Ididit. Hope this helps.
Roger Carter
Old 09-29-2004, 06:20 PM
65 chero's Avatar
65 chero
65 chero is offline
Thanks for the info. I have been looking for a mustang column here locally, but not too hard as of yet.
lisagoud
WTB - Parts & other
09-08-2014 05:52 PM
telefunkken
WTB - Parts & other
08-06-2013 02:50 PM
boss66
01-28-2011 12:38 AM
ArkyAl
WTB - Parts & other
10-01-2010 03:18 AM
Vampiro
02-16-2002 01:37 PM
Quick Reply: tilt steering column
