Changing a Fuel Filter 2001 F-150
Old 08-31-2004, 08:35 PM
Torb968's Avatar
Torb968
Torb968 is offline
Question Changing a Fuel Filter 2001 F-150
Can anyone provide some instruction on changing a fuel filter on a 2001 F-150 SC 5.4L?
Thanks
Old 08-31-2004, 09:52 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Yep, you first need to depressurize the fuel system. on the drivers side near the kick panel, there is a fuel shut-off inertia switch. Unplug it and crank the truck until it won't start.
Then, using the proper fuel line tool (available at mast any auto parts store), insert it into one of the fuel line fittings and pull the line from the filter. Some gas will come out, so watch your eyes. Repeat on the other line. Remove the filter from the mount and install the new one. Push the lines back on as far as you can get them, then tug on them to make sure that they are secure. Plut the inertia switch back in. Turn the key on for 5 sec. then turn it back off. Repeat 5 times. Then start the truck and look for leaks immediatly.
The filter is located on the drivers side framerail about under the rear seat.
Old 09-01-2004, 04:46 PM
Torb968's Avatar
Torb968
Torb968 is offline
Thanks for the info I'll tackle this this weekend. I had one changed around 43K at a jiffy lube and it took the guy all of 10 mins so I'm thinking it can't be that hard.
Old 09-01-2004, 07:49 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
NAW, I did mine about a month ago. About 10min's to do it myself.
vfer98
28
07-24-2017 04:34 AM
Concrete guy josh
06-07-2015 12:55 PM
LEWIS2001
Modular V8 (4.6L, 5.4L)
04-24-2015 03:50 PM
Shiner527
12-21-2013 06:19 PM
TinCocodrie
06-30-2008 11:52 AM
Quick Reply: Changing a Fuel Filter 2001 F-150
