water pump failure symptoms?
Old 08-20-2004, 06:26 AM
alkazoo's Avatar
alkazoo
alkazoo is offline
hi forum...never having had to replace the water pumps in either of the 2 ford trucks ive owned, im not quite clear on the symptoms of one going bad.Heres whats happening. 93 F150 supercab, 302 , 117k miles.
Last night at intersection idling, loud screeching under hood (not the same type of "screeching" normally associated with bad belts/idlers etc(been there done that). dissappeared when accelerated, only happened twice on the several mile trip and 10 or 12 stops/intersections. This morning sitting at light, noticed steam type smoke vapor coming out from under hood on passenger side,nothing thick but yet a vapor anyway, stopped at store popped hood,couldnt see any steam. Looked over hoses etc trying to see if i had pinhole leak somewhere, couldnt see any, no dripping or puddles under truck either. Have noticed antifreeze resevoir empty for quite some time. I always fill it to "cold fill" level, usually within 2 weeks its empty again although looking thru filler cap of radiator level is near top.....im stumped,,,is my truck giving me indication that something "big" is about to go wrong? appreciate the advice!!
Old 08-20-2004, 07:00 AM
Morky's Avatar
Morky
Morky is offline
could be many things
suggest to have cooling system pressure tested.
which should find the leak
where ever it is,
Old 08-20-2004, 08:48 AM
low-side's Avatar
low-side
low-side is offline
Water pumps usually have a weep hole where coolant drips out when the seal is bad. If you look at yours and its wet and/or stained you'll have your answer. If that's not it, you should look elsewhere if coolant loss is your only problem.
Old 08-20-2004, 09:59 AM
haybine's Avatar
haybine
haybine is offline
naturally look for the obvious as a water pump leaking at the weep hole. if that is ok, then get a pressure test of the cooling system. that will find where the leak is. could also be a intake manifold leak or a head gasket.
Old 08-20-2004, 10:57 AM
cmoore99's Avatar
cmoore99
cmoore99 is offline
It could also be a small leak in the radiator. Check the bottom of the radiator with a flashlight. Coolant will pool down there. A couple of doses of barrs leak fixed mine.
tr0y
35
12-13-2015 08:38 PM
cpye2
1999 to 2016 Super Duty
16
02-23-2015 09:49 AM
640 CI Aluminum FORD
2009 - 2014 F150
13
04-30-2012 08:37 PM
KJNDIVER
09-01-2011 01:43 AM
stroker393
01-18-2011 03:52 PM
Quick Reply: water pump failure symptoms?
