300ci Truck Parts
08-19-2004, 10:40 PM
on
300ci Truck Parts
Does anyone know where i can get a timing chain...new or used....for a 1981 Ford F150 with a 300ci I6? Ive looked all over and cant find anything for it, but as time goes by i clearly need it more and more every day! my best guess would be the salvage yard but man what a job!
Any suggestions are really appreciated,
Thanks
08-20-2004, 11:44 AM
300 I6 has gear to gear=no chain; matched gear set at NAPA is $82; but check Autozone or Advance Auto for any savings. I wouldn't recommend used gears; unless you know they in excellent condition.
08-20-2004, 11:55 AM
Check in with Vampiro in the Winnipeg area here at FTE. "Big Red", his '78 has a 300 and he's done a lot of work with it. He can probably give you some site references.
08-20-2004, 12:42 PM
Just checked Autozone $60 and at Advance they are $32 to $45 depending on brand
08-21-2004, 12:17 AM
on
MY truck pings at a lower RPM and diesels when i shut it off... are these signs that i need to replace the gears? Adjusting timing doesnt get rid of either.
10-04-2004, 09:53 PM
on
Does anyone think that it might be the EGR valve, or is it the timing gear...ive been told that a bad EGR valve will do the same thing? any thoughts?
Thanks
10-05-2004, 09:22 AM
on
Have you tried posting on the 300 six forum? I just got my 300 and can't be of much help yet...
Stan
