2WD Lift Kit for 1979 F150
Old 08-19-2004, 02:04 PM
jdency's Avatar
jdency
jdency is offline
I'm Looking for a 6" to 8" suspension lift for a 1979 Ford F150 2wd. I put one on my 82 F100 using BDS and superlift parts. However I can not locate a manufacturer for a 2wd lift for a 1979. I would appreciate any help. Thank you.
Big Mt. John
Old 08-19-2004, 04:02 PM
supercab4x4dually's Avatar
supercab4x4dually
supercab4x4dually is offline
Jeff's Bronco graveyard.
Old 08-19-2004, 05:39 PM
teds74ford's Avatar
teds74ford
teds74ford is offline
I have posted this before, but nobody seems to know a whole lot about it. It is an Ibeam flip. Here's a pic
https://www.ford-trucks.com/user_gal...=18635&width=2
Old 08-21-2004, 12:54 AM
bajascott's Avatar
bajascott
bajascott is offline
i did mine its a 77 f150 2wd. 6"national coils, and i bent the beams myself. extended the radius arms and corrected my castor . drive straight . check autofab.com he specializes in king pin suspension
Old 08-21-2004, 06:35 AM
teds74ford's Avatar
teds74ford
How did you bend the beams? With a sledge? I watched junkyard mega wars and they had a 2wd ford that the guys flipped the beams on, but then the tires really tipped bad. Ted
Old 08-21-2004, 10:51 AM
bajascott's Avatar
bajascott
i used a set of anchors in my buddys shop, they were chains in the concrete and a port-o-power with some heat . most would use a press but i am cheap and dont have a press that it powerfull enough.
caleballen95
01-24-2015 10:22 PM
julcan92
WTB - Parts & other
05-18-2014 10:08 PM
1979FordDiesel
06-06-2013 08:30 AM
79F150Seattle
20
07-15-2012 12:25 PM
Quick Reply: 2WD Lift Kit for 1979 F150
