oil filter lines
Old 08-18-2004, 03:21 PM
1952henry's Avatar
1952henry
1952henry is offline
oil filter lines
Please check my correctness. The bottom of the oil filter fits into the passage above the oil pan on the left side of the block, and the top of the filter fits into a tee with the sender unit. Am I right or not?
Thanks
Old 08-18-2004, 07:17 PM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
You have it right, be sure that there is a restrictor inline for the input of the oil filter. ...Terry
Old 08-18-2004, 11:10 PM
1952henry's Avatar
1952henry
Why, what kind?
Old 08-19-2004, 12:24 AM
Overkill-F1
One of the fittings will have a smaller opening thru it, it will restrict the flow of oil to the bypass filter. Only part of the oil will flow thru the filter. This is normal operation, if the restrictor is not in place, your oil pressure to the rest of the engine will be low or non-existent. ...Terry
Metrojd
Modular V10 (6.8l)
02-14-2014 09:50 AM
86sixbanger
51
07-26-2012 02:20 AM
tseekins
EcoBoost (all engine sizes)
12-11-2011 09:31 AM
rirwin
06-03-2005 02:16 PM
Quick Reply: oil filter lines
