flashing air bag light in 1994 f150
Old 08-10-2004, 06:12 PM
fordtruck88's Avatar
fordtruck88
fordtruck88 is offline
I have a 1994 f150 I-6 5spd XL with a driver air bag only, the air bag warning light keeps flashing repeditaly when the vehicle is running or being driven. Does anyone know what causes this or what it means.
Thanks
Old 08-10-2004, 06:37 PM
Andyman8282's Avatar
Andyman8282
Andyman8282 is offline
I'd probably take that to a dealer. maybe you are mistaking it for your ABS light? If so, we can help ya.
Old 08-10-2004, 07:56 PM
coder47's Avatar
coder47
coder47 is offline
It flashes in a particular sequence (I don't know all the codes, just this one), for example, 3, then pause, then 2, then long pause. For this particular sequence it meant that the clockspring needed to be replaced. It also effected my horn. $118 for the part and $74 to replace it, at a local shop.
Old 08-10-2004, 08:45 PM
fordtruck88
andyman- yep, im sure it the airbag light
Old 08-10-2004, 08:56 PM
fordtruck88
Thanks for the info. i havnt watched the light enough yet to find out if its blinking in a pattern, it just seems to go on and off with long pauses between.
Old 08-10-2004, 10:05 PM
John7894's Avatar
John7894
John7894 is offline
See if you cruise and horn are not working. If so, it's the clockspring. Mine's broken right now too.
John
Old 08-11-2004, 12:35 AM
badass truck's Avatar
badass truck
badass truck is offline
speaking of the clock spring in my 94 f150i hooked up an air horn. i just unhooked the original plugs and plugged them into the air compressor. needless to say this blew my clock spring. the horn stuck on a few times now nothing works cruise, or horn buttons. for some reason my local parts guy told me for a new clockspring it would be like 318. and also my air ag light is flashing
edo488
02-09-2014 03:15 PM
jterrell
03-16-2012 12:07 PM
Bob V
02-14-2009 10:45 PM
tgolen
11-21-2005 07:38 AM
knockback150
05-20-2005 12:39 AM
Quick Reply: flashing air bag light in 1994 f150
