What year wheels fit my 8-lug '86' F250
Old 07-27-2004, 03:58 PM
Chuky66's Avatar
Chuky66
Chuky66 is offline
I was checking out ebay and was wanting to just upgrade my ugly steel wheels to a nice looking wheel. I would be happy with the chrome stockers off a 95 or 96, as long as I didn't sacrifice the load range of my truck.
So what year stockers could I get to fit my lug pattern and tire size.
235/75/R16 I believe.
Chuck
Old 07-27-2004, 04:38 PM
fellro86's Avatar
fellro86
fellro86 is offline
I'm not sure about the new SuperDuty, but the years that share your body would be safe. I think the newer ones are likely the same, the difference would be the offset. Also, Dodge will trade, as will after market Chevy wheels, but not factory, and not the ones with proper offset for the chevs after 88.
Old 07-27-2004, 05:18 PM
Jimbare's Avatar
Jimbare
Jimbare is offline
all alone in the world
97 and back 8 lug ford and dodge are the same wheels, and most of the aftermarket 8 lugs will fit.
jim
Old 07-28-2004, 08:46 AM
dhermesc's Avatar
dhermesc
dhermesc is offline
jim
And when he says "BACK" he means back. I know 1961 - 1997 have the same bolt patterns - and it might even go back to 1955. The 235/85/16 tires will fit on all the factory 16 inch rims in that time frame with no problems regarding bead width. When your out looking don't accidently pick up some 16.5 rims - tires are getting pretty rare for that size and they'll screw up your speedometer.
Old 08-02-2004, 09:01 AM
fellro86's Avatar
fellro86
fellro86 is offline
The older rigs used split rims that most shops won't service. 16.5 rims are dangerous if you try to mount 16 tires on them. I was working a tire shop when a kid tried this. The tire exploded, sending tire and rim to the ceiling, bending a steel rafter before coming back don, He was lucky in that it blew him back out of harrm's way, but the tire machine was a mag machine with the rotating table, and it didn't fare so well, it was trashed entirely. The table was tilting, and oil leaked out from underneath. I currently have 16.5 aluminum rims on mine, but I will be replacing them when the tires are worn out. they came with the truck when I got it. The tires are the equivalent of running 245 75 r16's which is abaout an inch shorter than it is supposed to have. The speedo's accurate, got the ticket to prove it. It (speedo) must have been re geared to match the tires.
Old 08-02-2004, 06:31 PM
ClydeSDale's Avatar
ClydeSDale
ClydeSDale is offline
Originally Posted by fellro86
I'm not sure about the new SuperDuty, ...
SuperDuty rims are on a metric circle. 170mm vs 6.5" on pre-SD's.
Been there, tried that; it just don't work
Old 08-02-2004, 07:55 PM
fellro86's Avatar
fellro86
fellro86 is offline
That's kinda what I figured, and why I didn't say they would, as I hadn't had the exposure.
Old 08-02-2004, 11:00 PM
Chuky66's Avatar
Chuky66
Chuky66 is offline
Thanks for all the input. There must be a dozen used tire shops around here. Not to find one I'd trust.
Chuck
mtnxtreme800
22
10-11-2021 09:30 PM
Psyclopse
1999 to 2016 Super Duty
16
11-07-2014 10:35 AM
jleews6
03-31-2014 08:38 AM
2002exPSD
06-25-2012 07:51 PM
Sldrvr_1
2009 - 2014 F150
04-23-2010 08:01 PM
Quick Reply: What year wheels fit my 8-lug '86' F250
