valve lash
You probably could grind them some, but it would have to be done on a surface grinder. You can usualy shim them .03 safely. but you should check the geometry afterwards. It's important that the rocker tip sweep the valve tip evenly or you will have excessive rocker, valve tip, & guide wear.
crazy96863
20
05-25-2013 12:28 AM
bradford237
09-26-2012 06:42 PM
