Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
97 Explorer code P0446
Old 04-02-2002, 06:36 PM
Sid06's Avatar
Sid06
Sid06 is offline
Post 97 Explorer code P0446
mil light on and code P0446 cannister vent mafunction any ideas.
Old 04-03-2002, 12:17 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Did you refuel while the engine was running or forget to replace the gas cap & start the engine ?
Old 04-03-2002, 09:25 AM
Sid06's Avatar
Sid06
Sid06 is offline
No it started out as an intermitent problem but now it stays on all the time. I can clear the code and it will come back on somewhere around 150-200 miles. I searched the nhtsa site for TSB and found 1 #BC0312970501. The last time I had it at the dealer the lite went out before I got there and they said there were no hard codes and I haven't had a chance to get it back yet.
Old 04-03-2002, 10:55 AM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
Ok , Which engine does your Explorer have , Etc ?
Old 04-03-2002, 11:10 AM
Sid06's Avatar
Sid06
Sid06 is offline
5.0 Liter Auto AWD
Old 04-03-2002, 11:29 PM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
It may be the gas cap is leaking , faulty . Also check the fuel filler pipe , it may be venting some pressure due to a clamp being loose etc . Check all the Evap Emission hoses as well .
Old 04-08-2002, 11:55 AM
Sid06's Avatar
Sid06
Sid06 is offline
I inspected the gas cap and all the emmision lines from front to back.
I decided the valve on the vapor canister was stuck open the vapor canister is located on the frame in the rear mounted above the spare tire and gets alot of dirt and grime from the road thrown up on it. I have driven it several miles and every thing seems to be working no codes yet. Thanks for your help.
Phillip Fell
Old 04-08-2002, 12:57 PM
CobraXP's Avatar
CobraXP
CobraXP is offline
Villengineer
1999 to 2016 Super Duty
09-30-2014 03:53 PM
joshco
2004 - 2008 F150
01-15-2014 08:23 PM
Diesel_Brad
1983 - 2012 Ranger & B-Series
37
08-02-2013 04:18 AM
rangerguy52
01-29-2006 12:18 PM
jp756
06-10-2004 07:22 AM
Quick Reply: 97 Explorer code P0446
