4r100 Torque Converter Slip ??
Old 07-09-2004, 02:35 PM
Craig64's Avatar
Craig64
Craig64 is offline
Got a 2wd '01 F-250 and I recently had my front trnny seal replaced after it blew while backing my boat into my driveway. Had the seal replaced and shop said the torque converter looked good and fluid/screen looked clean so back it went.
Just got my boat out and started towing again and now I'm noticing a definite shuddering/pulsating in first gear while under heavy load. Only seems to happen when I'm towing. Boat weighs ~5,500 lbs.
Does this sound like my torque converter slipping?
Old 07-09-2004, 05:27 PM
CAT_man_963's Avatar
CAT_man_963
CAT_man_963 is offline
My first thought is check the driveshaft carrier bearing. I've read a few posts about that causing a vibration - especially when first starting off with a load. Mine does it a TINY bit 'cause I changed the 2" rear blocks to 4" without changing the carrier bearing spacing. Good luck and hope it's NOT the tranny!!
Old 07-09-2004, 09:53 PM
Craig64's Avatar
Craig64
Craig64 is offline
Thanks Cat_man. That makes a lot of sense cause I did recently add an additional 1.5" of spacer blocks to the rear to level the truck out and I didn't change the spacing on the bearing either. I hope you're right.
crewcab96
06-01-2014 01:42 AM
SANDDEMON08
6.4L Power Stroke Diesel
12-01-2013 10:57 AM
90f150302
22
06-10-2010 07:43 PM
PigFarmer
11-20-2008 09:58 PM
88bronc
01-13-2003 09:33 PM
Quick Reply: 4r100 Torque Converter Slip ??
