Colorado Chapter Join Chapter, Leader:
New to Ford Explorer
Old 07-06-2004, 05:52 AM
Golfmore's Avatar
Golfmore
Golfmore is offline
Where are the radius arms? (Please be easy on me). And how do I check the bushings? Thanks for any help.
Old 07-06-2004, 01:54 PM
mattadams's Avatar
mattadams
mattadams is offline
what year? You may not have them depending on your year.
Old 07-06-2004, 05:48 PM
Golfmore's Avatar
Golfmore
Golfmore is offline
1992.... I know it needs shocks, and am going to replace the fronts. Do you have any suggestions as to what kind etc? Thanks.
Old 07-08-2004, 03:17 PM
mattadams's Avatar
mattadams
Sorry I dont have any pictures for ya or anything... but basically the radius arm is the piece that connects to your front axle, just under the springs, and goes back a foot or two or so, bends in a little, and connects to the radium arm bracket. Replacing the bushings is a major job if its never been done before as you have to grind off rivets, etc. If it's already been done, they'll be bolts instead of rivets, but its still a major task.
Old 07-08-2004, 04:23 PM
Golfmore's Avatar
Golfmore
Golfmore is offline
Thanks for the help.
Old 07-14-2004, 06:40 AM
Golfmore's Avatar
Golfmore
Golfmore is offline
I put a full set (4) of Monroe Reflex shocks on this guy. What a difference. I have checked almost everthing, and all seems to be well. I bought the shcoks from PepBoys, and they put them on for $40. Not too bad for me. They also installed a bug deflector for free. And... then they called me and asked what I thought of their service. I will write a letter to the manager complienting them on prompt, competent service. Now I just have to get the heat shield for the cat welded. Having a little trouble finding some one that will do it reasonably.
Old 07-14-2004, 11:06 AM
Mike G's Avatar
Mike G
Mike G is offline
Check with Scott over at AA Perf muffler on Broadway for welding that heat shield....
--Mike
Old 07-15-2004, 06:02 AM
Golfmore's Avatar
Golfmore
Golfmore is offline
Thanks. I will do that on Friday....
Old 07-15-2004, 09:12 PM
Golfmore's Avatar
Golfmore
Golfmore is offline
Scott is going to do this Friday. Actually a trashed resonator, so it goes and a new pipe goes in it's place.
