Flathead in a Model A
Old 07-05-2004, 12:30 AM
90ebbronc's Avatar
90ebbronc
90ebbronc is offline
Yes i know this is a truck site, but who cares, lol. Im looking for a model A. Im wanting to make it into sorta a rat rod. Just about everyone you see that is a hot rod, has a small block chevy in it. Well i dont believe in cross breading like that. I have found a flathead v8, and would really love to put it into the Model A.
Ok my question is, would i have to do anything to the frame to hold up to the flathead. Or should the frame be strong enough to hold the flathead, plus not twist under its "huge" lol power. I figure if all else fails, i can box in the original frame, no biggie. I just want to keep most of the car original, for the exceptions of the flathead and power steering and of course the tranny and rear end. I guess you could say, that i want the body, frame, and possibly the front susp (if at all possible to do and still have power steering). If thats not possible, then please make suggestions for a front end and still keep solid axle. This will be driven every day thats its pretty, and on weekends. Basically this will be a second daily driver, just not driven as often as the Bronco (there is my ford truck so i wont get kicked out LOL).
Thanks for all the help, and sorry for the long book.
Old 07-05-2004, 01:38 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
You'll get a better response at one of the following:
http://www.fordbarn.com/
http://groups.msn.com/FordFlathead19...pgmarket=en-us
Old 07-05-2004, 03:36 PM
90ebbronc's Avatar
90ebbronc
Thanks for the links. Also can you run unleaded gas in a flathead, or should you buy the lead additive for it?
Old 07-05-2004, 07:26 PM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
I don't think you should worry about lead additive for the valves/seats in a Flathead.
...Terry
Old 07-05-2004, 09:21 PM
90ebbronc's Avatar
90ebbronc
So flatheads can run on unleaded gas without any problems?
Old 07-05-2004, 10:50 PM
SP_51-F1's Avatar
SP_51-F1
SP_51-F1 is offline
Yeah, they will run just fine.
Old 07-06-2004, 12:19 AM
90ebbronc's Avatar
90ebbronc
Awesome news to hear. Ok so now what about dropping it into a Model A, very many modifications to the frame to do so?
Old 07-06-2004, 09:30 AM
mtflat's Avatar
mtflat
mtflat is offline
I'm not aware anyone here has done this mod, but 4tl8ford gave you the two best links to ask this question. Mike Bishop haunts both and has a book out about the transplant.
Old 07-06-2004, 02:24 PM
90ebbronc's Avatar
90ebbronc
whats the book called?
Old 07-07-2004, 10:14 PM
Kyfireman's Avatar
Kyfireman
Kyfireman is offline
Its something like "How to build a Hot Rod Model A" or "How to build a traditional Hot Rod" something like that. Do a search on Amazon for the author "Bishop" and "Tardel" They are like $15.00 on Amazon Good luck!
mike.rogers
13
12-26-2015 12:52 PM
Butchashop
1947 and Older Ford Trucks
12-09-2013 08:59 AM
Lukas42104
27
07-11-2012 01:09 PM
3rdshiftDiscretion
16
06-18-2011 05:08 PM
restoringmy46
24
10-25-2006 09:15 PM
Quick Reply: Flathead in a Model A
