code p1309
code p1309
>A P1309 is a camshaft position sensor code. The manual says
>to hook up a breakout box and monitor the voltage from it.
>If it isnt right you replace the sensor.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=10
this site says it is misfire monitor problem
i have already replaced cmp per code p0340
thanks
confused
thanks
confused
code p1309
This is right out of the Ford shop manual........
HD40 CHECK CMP SENSOR OUTPUT
Diagnostic Trouble Code (DTC) P1309 indicates Misfire Detection Monitor is not enabled.
Breakout box installed, PCM disconnected.
Connect digital multimeter between PCM test pin 85 and test pins 51 or 103.
Bump engine in short burst with the starter without starting engine for at least 10 engine revolutions.
Does digital multimeter reading switch between low (less than 2.0 volts DC) and high (greater than 8.0 volts DC)?
Yes
Note: A Hall effect type CMP sensor that is installed out of synchronization will produce a DTC. VERIFY the correct installation by referring to the Powertrain/Engine Group in the Workshop Manual. If the CMP is installed properly, REPLACE PCM. RESTORE vehicle. RERUN Quick Test .
No
REPLACE CMP sensor. RESTORE vehicle. COMPLETE Misfire Monitor Repair Verification Drive Cycle. RERUN Quick Test .
Yes
No
crazy96863
11-30-2014 10:54 PM
almus
06-09-2007 01:49 PM
Xdrive
1983 - 2012 Ranger & B-Series
02-10-2007 05:58 PM
