1986 ford Ranger over fuel problem
Ok here it is I hope some one can help its 1986 Ranger with a 2.9L V6 Auto 4x4, well to start with it seriously over fueling also it idles very roughly and even stalls out sometimes, when I’m trying to hold it at a speed it acts like it is missing (I guess that’s from over fueling as well and it also pukes out lots of black smoke, it goes through way too much gas for a V6), but when I speed up fairly hard it acts fine until I try to maintain speed again, I have already put a tune up into it and a new EGR as well a fuel regulator has anyone ever had this problem and do they know how to fix it????? thanks
Very good advice 87XLT, Risky don't just throw parts at this problem, as there are a number of things that will mess with the fuel mixture, as mentioned the MAP, or MAF or a temp sensor, ect, ect.
Taking the time to pull the codes can save a lot of time, money & guess work & likely point you to the troubled system or part.
So pull those codes & let us know what you find.
Risky & Brainless, my local AotoZone & Advance Auto both use the Actron CP9150 scanner kit. It uses the CP9145 scanner & the needed cable to hook up to your dignostic connector.
This scanner can monitor live feeds from sensors into the computer, as well as read stored codes.
They don't charge anything here to scan your computer.
Just another option for you to consider in getting your codes pulled.
The regulator can stick, and cause fuel to dump in there. Buy the gauge for about $35, and check the pressure. You'll hate Ford when you have to pay for the new regulator, as it is over $100. ANd the fuel line retainer clips are almost impossible to remove.
But, your fuel mileage wil almost double...
tom
tom
Hey All
I just replied to 1800GL on this forum with a suggestion on his fuel problem. I've seen a problem with the fuel press regulator failing open, causing severe flooding at throttle-up. Idle was fine and there were no fault codes. It was a friends Ranger and he spent much time, effort and money on parts. In the end it was the regulator. He had the 2.8 but my 2.9 has been fine so far, but I won't forget.
Good luck
Good luck
