Cam Question
Old 05-23-2004, 09:24 AM
Steve_B's Avatar
Steve_B
Steve_B is offline
Cam Question
I,ve been taking a closer look at my flathead V8 and found a few interesting things
1, I have a 4" stroke
2, I have adjustable lifters
I am wondering if I have a standard cam, I measured the valve lift and both inlet and exhaust are .310", Dose anyone know what the standard cam lift was
The engine was built in Canada model C1BA
Old 05-23-2004, 05:32 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
I believe the Stock Ford cam for 49-53 was about .296.
Old 05-24-2004, 04:28 PM
51dueller's Avatar
51dueller
51dueller is offline
If you have the timing cover off the engine. Look at the front of the camshaft. It should say EAB-A or 8BA-B. If it doesn't you don't have a stock ford camshaft. This only applys to the 49-53 engines.
Old 05-25-2004, 02:02 AM
Overkill-F1's Avatar
Overkill-F1
Overkill-F1 is offline
My '52, C1BA/8RT has a EAB-A cam, .328" lift. ...Terry
Old 05-28-2004, 11:49 AM
Steve_B's Avatar
Steve_B
Steve_B is offline
Thanks guys
I checked the cam and it's marked 8CM, maybe a Mercury cam ?
Stephen
Old 05-30-2004, 09:36 PM
51dueller's Avatar
51dueller
Yes that is a mercury cam. I forgot about this one. The other numbers I listed are for the Ford engine.
telemaster444
Engine Swaps
09-16-2016 08:55 AM
JRS2
05-01-2015 09:35 PM
kopfenjager
02-10-2015 07:56 AM
GrossPapi
21
09-04-2013 09:06 AM
EXOPAR
01-17-2003 11:58 AM
Quick Reply: Cam Question
