Bore Spacing And Crank Dimensions For 477/534
Old 05-17-2004, 08:35 PM
baddad457's Avatar
baddad457
baddad457 is offline
Need bore spacing and crankshaft dimensions for the 477/534 engine.
Old 06-02-2004, 08:25 PM
Kenny's Avatar
Kenny
Kenny is offline
Not sure if this is what you are looking for. If not, I apologize.
For 401, 477, and 534 SD Engines:
Crankshaft Main Bearing journal ........................... 3.1246 - 3.1254
Piston to Bore clearance (bottom of skirt).............. 0.0011 - 0.0029 (wear limit 0.005).
I hope this helps.
Old 06-02-2004, 09:12 PM
baddad457's Avatar
baddad457
Main bearing journal dimension is part of it, but I was also looking for the bore spacing, which is the dimension from ctr to ctr between adjacent bores. I was just curious because I thought I was about to have one handed to me and wanted to see if any parts would interchange with the FE's. Turns out the motor was a 370 ( 385 series) . Thanks for the reply anyway.
Old 09-24-2004, 10:25 PM
Loan Ranger's Avatar
Loan Ranger
Loan Ranger is offline
Well, then its time to hop it up with some 429 parts!! I hope you get the engine and enjoy the project!!
Old 09-25-2004, 06:59 PM
baddad457's Avatar
baddad457
Nope, that 370 is history. Nothing in there worth saving. Did save the odd ball rods, the rockers and fulcrums, they'll fit the Cleveland and 400's ( rockers & fulcrums) The rods are shorter than 429/460's maybe good for some custom project later down the road.
Nolan Harris
401, 477, & 534 SD Engines
29
09-21-2023 09:22 PM
iceman101
1999 to 2016 Super Duty
11-02-2019 08:38 AM
Jim534
09-01-2017 07:16 PM
comstock
41
05-04-2017 07:15 PM
beegeezy
29
10-05-2006 08:13 PM
Quick Reply: Bore Spacing And Crank Dimensions For 477/534
