Gauges peg out ignition switch is turned on
Old 05-13-2004, 09:44 PM
hgall's Avatar
hgall
hgall is offline
Help. My daghter has a 2002 F 250 psd. I went looking for a dead battery problem. I checked the alternator and it is only puting out 12.4 volts but here is a strange symptom, when I turn the ignition switch to the on position all the dash gauges peg out for a moment. I started pulling fuses to see which on would stop this and it turned out to be the power point 3rd row. I reinstalled the fuse and it would not do it again. This is the 2nd alternator in a year could there be a connection? Also I am not sure if the gauges did this with the 1st alternator. Thanks in advance for your help
Hgall
Old 05-14-2004, 09:51 AM
Daisy096's Avatar
Daisy096
Daisy096 is offline
Check out where the gauges are grounded to, I also have a 02' PSD and on the passenger side of the truck there is a ground strap (cheap one at that) that runs from frame to the body. I replaced this strap with a copper strap. This may be your problem (hope so). Check it out
Old 05-14-2004, 10:13 AM
trakman's Avatar
trakman
trakman is offline
My 02 done the gauge thing the first time I had the batteries unhooked and then hooked them back up. I would guess that it's resetting everything. Don't know about your alternator problems.
Old 05-14-2004, 10:18 AM
Craze's Avatar
Craze
Craze is offline
What kind of gauges are they? My Autometer gauges do that as a function of calibration each time they are powered up.
Old 05-14-2004, 10:26 AM
basstardo's Avatar
basstardo
basstardo is offline
If you've unhooked the battery that is perfectly normal. I disconnect the negative on my battery all the time to do things to my truck, and when I hook it back up and turn on the key the guages go nuts. Unless this is happening all the time, I wouldn't worry about it since it's normal for the guages to do this when you hook up the battery again.
Terry
Old 05-14-2004, 09:27 PM
hgall's Avatar
hgall
hgall is offline
Thanks for the everyones help. I knew the alternator was not putting out. I think the advise about the batteries being unhooked is solid. They were not unhooked but were pretty low. The Ford dealer installed a new alternator free of charge as it was only 5 months old and the gauges quit acting up. Again thanks all.
DTW79
04-04-2023 07:36 AM
PASSIONATE_GRANDPA
10-21-2011 07:54 PM
78_f150
05-02-2010 04:50 PM
wreckinball
77
01-19-2010 08:32 PM
captamb1
01-19-2009 06:00 PM
Quick Reply: Gauges peg out ignition switch is turned on
