Shift Cable Adjustment - How?
I'm trying to adjust the shift cable on my 1996 Ranger 3L.
The Haynes manual says:
"Pull down on lock tab on the shift cable and remove the fitting from the manual shift level ball stud with a screwdriver".
Well, I found the shift cable, LOL. But I see no lock tab. What does it look like? Is it built-in to the roundish plastic thing that goes through the big metal bracket? I'm scared to mess with that because if I break that plastic piece then I'm really messed up! Am I even looking at the right thing? ;-)
Any help out there?
Any help out there?
The manual shift lever you are looking for is rearward from your picture. Sticking out of the side of the trans is a shift lever with a plastic connector that slides over the ball stud on the lever. I never heard of adjusting the lever, is your speedo gear indicator out of position with the letters PRNDL?
ranger pat:
"is your speedo gear indicator out of position with the letters PRNDL?"
Well, sometimes when I shift it doesn't go into gear. It doesn't feel as if it's slipping or anything, it just ain't going in. The troubleshooting guide said to adjust the shift cable. It happens very rarley and drives real good.
But the Haynes manual isn't real good on this pocedure. It is more confusing than anything else. The labels on the pictures don't correspond to what the text says. I figured adjusting it couldn't hurt. If it still does it then I know it's something else.
Wheather it's the thing I took a picture of, or the thing further up attached to the actual shift lever I still see no "lock-tab" that I'm supposed to pull down.
The Haynes manual diagram points at a "lock tab" on the thing I took a picture of above.
Where ever it is, it will have to loosen the cable so you can adjust the length before you lock it back in place. There is a kind of tab just behind the thing I took a picture of, but it doesn't seem to do anything. I don't think it is for adjustment.
Here is a picture of the Haynes Shift-Cable Diagram:
http://home.comcast.net/~kr4495/Rang...bleDiagram.jpg
I'm stumpped. Hasn't anyone here adjusted their shift-cable? There must be some trick to it.
Shift Cable Lock Tab
This is probably a dead issue by now, but as reference for those who might be considering this in the future:
As you look at the shift cable from underneath, you will see where the end "snaps" onto a ball stud. From there it continues towards the front and goes through a metal support.
If you look at the assembly in that area, you will notice a piece that is white in color, while the rest is black. That white piece is your lock tab.
Prying the edge with a screwdriver will allow it to slip out enough for you to make the necessary adjustment.
My problem, on the other hand, is that I have tried that adjustment, and I still can't get mine to shift right (won't go into Park) on a 1995 XLT 3.0 with 4R44E. The PRNDL switch on the tranny seems fine when moved by hand.
I think I am looking at cable replacement; but I do wonder: does the excessive slop in the shift lever indicate a problem in that area, and do those ever need to be replaced?
xirxious
07-25-2011 08:44 PM
Muv
03-31-2008 12:09 PM
