Cracks in Block
Old 04-27-2004, 09:02 PM
skeleton33's Avatar
skeleton33
skeleton33 is offline
Cracks in Block
What's all involved in repairing typical cracks between the bolt holes and water holes and/or under the valves?
Thanks.
Old 04-28-2004, 01:08 PM
51dueller's Avatar
51dueller
51dueller is offline
If it's just the stud to stud crack you can just leave those alone. If you have cracks in the valves those will have to be drilled, screw it shut and grind it smooth. A professional should do that.
drewduncan15
02-01-2020 06:24 PM
szotty
09-22-2013 10:23 PM
NVRAGN
09-21-2010 01:18 PM
393STROKER
12-21-2008 06:42 PM
propane32
10-18-2006 10:06 PM
Quick Reply: Cracks in Block
