propane conversion?
You might be referring to propane injection rather than a propane conversion. I've got propane injection on my truck, where the propane is injected into the airflow pre-turbo, and improves the efficiency of the diesel burn, plus adds power. Used sparingly, it can/will improve mpg, but I keep mine wicked up for additional power. I still get the same/better mpg than before, but I get there much sooner.
I have to say Most Guys DID Not do propane to get better Mileage, They do it for ALot more Power. Even if it does give some extra MPG its offset by Haveing to Buy Propane. IMHO the Powershot2000 Is the best system. It dont need Mixers and heaters To make it work, It is Just Vapor and Works real well. The way I have mine set I get about 85 Extra HP To the rear Wheels.
I started thinking about doing this, but after posting this, just reconsidered, after looking at another post where a guy just added a modified exhaust and chip and blew out his engine. Ford said they would not warranty the engine. Going to cost him $13,000 to replace. I was trying to find more ways to increase fuel efficiency- with the increases of gasoline prices these days- but as you said, it's bascially offset. Being a new truck, I think I'm pretty much stuck with the way things are until my warranty runs out. Thanks for the reply Big Bully and GOOD LUCK! (I may reconsider down- the- road.)
If you want better mileage and do not want to void your warranty, get a free-flow tailgate or a camper shell or a tonnaeu(whatever) cover. Also if your engine has been taken care of, and you do not think it will have problems(before warranty is over), get you a Tymar air filter and a 4inch exhaust.
If you want even better mileage and sound, take off the muffler and the cat. Sounds great! But i think that the exhaust and air filter will void your warranty, so only put those on if you are COMPLETELY sure it is what you want to do.
