i need to know if a stock 01 lightning can handle 12 boost?
I just bought my 01 ford lightning, and it says its running 8 psi of boost stock, and im thinking about buying a 6lb pulley kit for the supercharger that adds 6 psi,
can the stock internals run 12 psi or if not, what will I have todo to make sure it doesnt screw up the motor?
Thanks
Scott
Thanks
Scott
12 psi
with the right tune in the chip you should be ok, for awhile, i ran 4 and blew 4 rods out the side of my block. if you are thinking of running more than the stock set up, put the forged internals in it and build the lower end. ive read of lots of other L owners blowing the 01-02 motors with a chip and 4-6 lb. pulley
I have since gone to a built lower end with ported heads, KB, cams...etc.....
But I never blew my stock block.... and it took a beating......
I think sum trucks can handle it more........
Meydawg51
27
04-06-2015 03:41 PM
schamsy
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
17
10-10-2011 03:24 PM
TennesseeMustangPerf
1999 to 2016 Super Duty
17
04-13-2010 12:44 PM
