when and what
Old 03-15-2004, 08:52 PM
neer150's Avatar
neer150
neer150 is offline
when and what
when where the engines produced and what where they related too.
Old 03-15-2004, 10:32 PM
Ds7776's Avatar
Ds7776
Ds7776 is offline
from what ive read they were made in th60s and ive only seen one 534 in a 74 F750 i think it was a 750 anyway. I asked about them a while ago from what i understood they were a LARGE FE if im wrong please tell me i had the chance to buy a 477 but ran short of money, I stilll really want one.
Old 03-16-2004, 05:49 PM
Kenny's Avatar
Kenny
Kenny is offline
These engines were used in the late 1950's large trucks.
The 401 came with the F-850, F-950.
The 477 came with the F-1000 (standard), F-1100 (as an option)
The 534 came with the F-1100
Same for C-series (tilt cab), and T-series (tandem)
Not positive on this one, but I think they may even preceed 1957.
The Super Duty engines were kind of in a "family" of there own.
Old 03-17-2004, 05:48 PM
Thomsen's Avatar
Thomsen
Thomsen is offline
HOLY COW! those are some big cube motors...does anybody know the hp and tq specs on these monsters?
Old 03-17-2004, 07:49 PM
Kenny's Avatar
Kenny
Kenny is offline
From my '59 Ford Truck shop manual......
401 SD V-8
Horsepower..................226 HP @ 3800 RPM
Taxable Horsepower.....54.00
Torque..........................350 foot lbs. @1800-2300 RPM
477 SD V-8
Horsepower..................260 HP @ 3600 RPM
Taxable Horsepower.....65.00
Torque..........................430 foot lbs. @1800-2300 RPM
534 SD V-8
Horsepower..................277 HP @ 3400 RPM
Torque..........................490 foot lbs. @1800-2300 RPM
Old 03-18-2004, 02:42 AM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
I'll have to dig out my 81 heavy truck shop manual... I know the 477 and 534 are in there, but, I forget if the power ratings are too...
Old 03-18-2004, 05:26 PM
FERacing66's Avatar
FERacing66
FERacing66 is offline
well the torques prettey good on the 534 but is there any high peformance products you coud get for it.
Old 03-18-2004, 07:46 PM
82F100SWB's Avatar
82F100SWB
Nope, these are strictly industrial engines, low compression, low revving high torque...
They are positively HUGE also...
That one is missing the oil pan, that's a Holley double pumper on there, and those are 8x8's(IIRC, might be 12x12's) it's sitting on...
Have fun fitting it any automotive application.
Old 03-20-2004, 06:19 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
That ain't no double pumper on there, that's a single line Holley, probably around 600cfm.
They do favor the FE design though. Especially the heads. Where does the distributor go? behind the turbo charger looking waterpump?
I've never seen any of these dinosours before. It looks really heavy!!!
Old 03-20-2004, 06:44 PM
82F100SWB's Avatar
82F100SWB
IIRC, double pumper means it has an accelerator pump on each bowl... Which that unit does, it's just an oddball industrial application carb.
I forget if the distributor is at the front, or goes on top of the governor at the rear... been a while since I had the tarp off of that thing.
Old 03-20-2004, 08:53 PM
Kenny's Avatar
Kenny
Kenny is offline
The distributor is up front, behind the water pump.
Old 03-21-2004, 11:18 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I see, It didn't look like it had a rear pump, but it is hard to tell by the angle of the picture. I stand corrected.
Old 03-23-2004, 09:53 PM
mikebon08's Avatar
mikebon08
mikebon08 is offline
I've seen 534s as late as '82, a lot of small-town fire trucks using Ford cabovers have 534s. Bunch of them still around too.
Old 04-05-2004, 08:28 PM
534Seamaster's Avatar
534Seamaster
534Seamaster is offline
There are two 534's for sale on EBAy right now.One for $500 running. 534's came with a Holley that was a governed unit with a second set of throttle plates connected to the governor. The Holley was rated at something like 375CFM. I have a Ford 534 Seamaster Marine engine running in a boat. Smooth & dependable but not very exciting, except to know it will still be running for a long, long time.
Old 04-17-2004, 10:47 PM
alvaze's Avatar
alvaze
alvaze is offline
HI,i have a truck with 534engine, its very strong, but, i need convert to gas my truck,
the problem is with power, because its reduce,
where find information about 534 specifications i need links
Quick Reply: when and what
