Excessive Egr Flow??
OK GUYS-- HERE IS A QUESTION FOR SOMEONE OUT THERE!!
CHECK ENGINE LIGHT CAME ON TONIGHT
WENT TO MY LOCAL 24 HOUR A/Z TO HAVE THE CODE READ
CODE CAME BACK AS EXCESSIVE EGR FLOW
WHAT CAN CAUSE THIS??:worm:
THE GUY AT A/Z (WHO I HAVE DEALT W/ FOR QUITE SOME TIME) SAID TO RUN SOME REALLY GOOD CLEANER THROUGH THE GAS.
ANY OTHER OPTIONS????
PS THIS IS ON MY 01 SCAPE- 3.0 W/ 51000 MILES
egr
my dpfe sensor when out on my escape and autozone said it was the egr valve but when I took it to the ford place they told me that it was the dpfe sensor that tells the egr valve to open and close mine was stuck closed I was getting 17mpg after I got it fixed I get 22mpg highway help out alot 63000 on it right now
check your DPFE sensor first before you check your egr valve.
Originally posted by sriggle
Update__ All fixed courtesy of Ford! went in for one thing, came out w/ two things fixed guess they figured out the seat belt need to fixes as well!
scott4401
1997 - 2003 F150
04-13-2009 11:24 AM
