Propane + Super Chip =
Old 03-07-2004, 09:39 PM
96ford4x4turbodiesel's Avatar
96ford4x4turbodiesel is offline
Can you run propane and a SuperChip at the same time? I was reading on Superchip.com and they said you cant run propane with it. Please tell me ya can b/c if not that will break some dreams of mine Propane+SuperChip=about180more HP!! Right now i have the SuperChip microtuner and am thinking about buying propane injection.
Old 03-07-2004, 09:43 PM
FarmerPhilCo's Avatar
FarmerPhilCo
FarmerPhilCo is offline
do you run at or manual transmission?
Old 03-07-2004, 09:45 PM
auto
Old 03-07-2004, 09:48 PM
FarmerPhilCo
i wouldnt think about running a chip. they really hurt the tranny in the long run. take it to an international dealership and have then reconfig the comp after you add propane.
Old 03-07-2004, 09:51 PM
yeah but i already have the chip that cost $320
Old 03-07-2004, 09:52 PM
FarmerPhilCo
i would sell it. or at least speak with some people that have had them in your model year truck and see how they feel about them. the aeod is not the strongest tranny, they put the same things in lincoln town cars
Old 03-07-2004, 10:05 PM
the superchip shouldnt be too bad for the tranny as long as your not towing
Old 03-07-2004, 10:15 PM
FarmerPhilCo
just be careful. that tranny is weak regardless of towing
Old 03-07-2004, 10:18 PM
thanks for the advice but that to the side, would i still be getting 80hp from the propane and 80 or 90 from the chip if they were mixed
Old 03-07-2004, 10:28 PM
jtsmith22's Avatar
jtsmith22
jtsmith22 is offline
__________________________________________________ _
. . . the aeod is not the strongest tranny, they put the same things in lincoln town cars
How can this be? I don't dispute that Ford could have built a better tranny for the SD, but the same tranny as a Lincoln - tell me it ain't so!
Old 03-07-2004, 10:32 PM
FarmerPhilCo
yes sir
the same tranny in the lincolns, ford full-size cars, and 1/2 ton and up ford trucks.
I was shocked as well when I first figured it out
Old 03-07-2004, 11:11 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
You're going to need a very expensive professional rebuild on the tranny to beef it up for that kind of power. Plus an EGT gauge. Also, a full 5 inch exhaust and intake kit. Even with all that, its not going to long last before something breaks.
Old 03-08-2004, 02:55 AM
Quadzilla's Avatar
Quadzilla
Quadzilla is offline
I run propane and a high hp chip, and am still plugging away without any tranny problems. You won't see that much power improvement, though. The propane is worth an honest 80rwhp, but the chip doesn't add that much on a dyno. The combination chip/propane has added a little over 100rwhp to my truck.
Old 03-08-2004, 07:43 AM
cangim's Avatar
cangim
cangim is offline
If this is the case, then how come did my 98' f150 (5.4L Auto) have a five speed auto, 4+ O.D.? my 99 350 is a 3 speed + O.D.
Come on man, the lincoln would bareley keep the thing off the ground.
Old 03-08-2004, 08:43 AM
Frost13's Avatar
Frost13
Frost13 is offline
No, your truck has a 4 speed auto with an elec. overdrive.
I think you should have the 4R100.
They have had 4 speed auto's since the first E40D was put out.
Quick Reply: Propane + Super Chip =
