Transmission with PTO provision - Is it stronger?
Old 03-07-2004, 10:57 AM
F15099's Avatar
F15099
F15099 is offline
Somebody on one of the other topic sections mentioned that a transmission with the PTO provision is build stronger than a standard transmission and and therefore would be a good option to add. I will be towing a boat (6000#) and wondered if this would be added insurance. I have ordered a F250 CC with the V10 and still have time to add it if it is beneficial.
Any suggestions?
Thanks.
Old 03-07-2004, 02:05 PM
Lou Braun's Avatar
Lou Braun
Lou Braun is offline
I believe the PTO is in the transfer case and not the transmission (might want to double check me on this one). If you have no plans to use the PTO, I would not bother ordering one.
The standard transfer case is tough and stands up well to any towing demands that you may place on it.
Lou Braun
Old 04-08-2004, 05:09 PM
PSD Six-Point-Oh!'s Avatar
PSD Six-Point-Oh!
PSD Six-Point-Oh! is offline
About the PTO: I was told......
Hi!
I just ordered a new 250 6.0 from Van Bortel in NY and
the good fellow there (!) Jeff, says *he* has been told
by factory guys that the PTO trans has heavier clutches
and bearings. I tend to believe him as he's been great with
his help to me in my choices and gets an A++ from me on this.
I will be towing occasionally, but not a lot. I sat on the
fence about ordering this since I thought being heavier-duty
would be a good thing, so I ordered my truck with it.
Does anyone else know any more about this transmission?
Thanks,
PSD Six-Point-Oh!
Old 04-08-2004, 08:58 PM
RTM's Avatar
RTM
RTM is offline
All the ZF 5-speed trans have a PTO cover on both sides of the trans near the bottom and yes the ZF is the stronger trans.
Old 04-08-2004, 09:45 PM
aspork42's Avatar
aspork42
aspork42 is offline
at my work i drive a 350 flatbed tow rig w/pto, i'll get under it tomorow and see what i can find out.
i can tell you that it is a 5-spd stick, so 4w/od, and i can shift through all the gears in about 30 yards because its a diesel...oh, and i have to push the clutch to operate the PTO **** to run the hydrolics on the bed.
Old 04-09-2004, 08:31 AM
Casey's Avatar
Casey
Casey is offline
The 4R100 with the PTO had heavier duty parts, but they put the heavier duty parts in all TorqShifts, with or without the PTO option.
Old 04-09-2004, 07:36 PM
aspork42's Avatar
aspork42
aspork42 is offline
well i forgot to check our tow truck, but i thought about it, the pto cant come off the transfer case, our truck is two wheel drive, and besides that it would mean leaving the tranny in gear to use the pto. this might make the truck roll away...
i also wanted to add that this truck is an 89, and has only been through one clutch, prob cause it is a diesel and cant even turn fast enough to burn it.
Dean06919
04-26-2016 07:38 PM
kblazk
6.7L Power Stroke Diesel
03-11-2013 09:56 PM
presrch
08-31-2004 05:09 PM
mchild
02-04-2003 05:57 PM
Fred H
1999 to 2016 Super Duty
12-16-2002 05:10 PM
Quick Reply: Transmission with PTO provision - Is it stronger?
