Michigan Chapter Join Chapter, Leader: Toyman
Ford f250 STRIPPED OIL PLUG CANT REMOVE HELLLLP
Old 02-27-2004, 02:01 PM
awe911's Avatar
awe911
awe911 is offline
i just bought a f250 1987 and i went to change the oil but to my surprise the plug just spins both ways not tightening or loosening. it leaks about a dime size puddle per day but i would like some ideas before i start anything
Old 02-27-2004, 02:19 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Cool Oil drain plug
I have owned Ford trucks for 23 years and I have had that problem more than onece. Is the oil pan in good shape? My 89 F150 300 six 4x4 oil pan went last fall. Now as far as the oil plug go,es try backing off with preshire . Then then talk to somebody about an oversize plug for that I have used it for years and no problem your are better off to have a mech. work on it for you so if it fails you can blame him. Good luck and do not worry because it is a common problem.
Old 02-27-2004, 02:22 PM
awe911's Avatar
awe911
awe911 is offline
thank you will try the pressure and if that dont work then i will take it in...also the pan is in good shape.
Old 02-27-2004, 03:01 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Oil plug
Well get it fixed fast I have seen them start to leak more & more as time went on. Good luck let me know how it works out.
88 F250 2wd 300 six 5spd pickup
99 F250 2wd 5.4 auto 8ft rack body dump 4.10
00 F350 4wd power stroke 6spd 9ft rack body 4.10
04 F250 4wd 5.4 6 spd pickup 3.73
Old 02-27-2004, 03:27 PM
awe911's Avatar
awe911
awe911 is offline
well after i wrote last i went out and pulled that sucker out with some vicegrips no prob...will let drain and tommorrow i will be putting the new oversized plug in..keep ya posted.............
QUESTION?
i have a rod knocking,if i use 20w40 oil will that help quiet that knock since it is thicker?I am saving up the 2300$ to get a new engine but in the meantime will that work or what do u think?
Old 02-27-2004, 03:35 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Cool Rod
Chance,s are if it knocking it is probbley bent keep the rpm dowm to min. What is the motor anyways? And how many miles are on the truck? I will call my mech and ask him the ? about the oil I get back to you in a few hours.
Old 02-27-2004, 03:40 PM
awe911's Avatar
awe911
awe911 is offline
it is a v8 5.8 with 154000 milesi dont usually drive over 40 just to get to and from work right now....its such a perty truck i cant junk it i bought it for 800$ with a brand new edelbrock carb 4bbl new sensors new computer brain new starter 33' all terrains goodrich lots of tread a dana 60 the body is in awesome condition could use a little tlc around the tirewalls but as far as rust and scratches dents go NONE and the interior is in perty good shape so i think its worth the $ to fix it up.its a 1987 ford xlt lariat 3/4 quarter ton with 154k miles
Old 02-27-2004, 03:50 PM
85BigBlock's Avatar
85BigBlock
85BigBlock is offline
If the oversized drain plug doesn't work, look into a piggy back plug(a small drain plug inside a larger one), but only as a last resort.
Old 02-27-2004, 03:54 PM
awe911's Avatar
awe911
awe911 is offline
will do thanks for all replys when i need help this is always the first place i come to you guys are awesome stay cool
Old 02-27-2004, 03:58 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Drain
If I where you I would think about a used low mileage motor sounds like that one is getting tired. I only got a 140,000 miles on my 5.8 motors but I work the snot out of then with my work. You can find low mileage motors that came out of wrecks cheap Give that some thought if you did that you will save more money than rebuilding this one.
Old 02-27-2004, 04:30 PM
awe911's Avatar
awe911
awe911 is offline
thought about it but can you trust em?you think i can get one in.staying under 2300$
Old 02-27-2004, 05:32 PM
sglaine's Avatar
sglaine
sglaine is offline
Posting Legend
Cool Oil Pan
Some salvage wards will let you hear the motor 1st before you buy. It go like this buyer beware. I am sure you can find something good ware you live. Ask around I bet you can find a great motor for around a $1000.00 or less check it it wont cost anything to check into it. Good Luck
Vinford
15
07-19-2012 01:08 AM
fuzzy1626
07-01-2007 12:21 AM
ronnjonn
10-23-2006 08:01 PM
roaringsaleen
10-29-2005 10:52 AM
amckeag65
08-20-2002 08:29 PM
Quick Reply: Ford f250 STRIPPED OIL PLUG CANT REMOVE HELLLLP
