Colorado Chapter Join Chapter, Leader:
Sraight Axle Swap
Old 02-26-2004, 08:01 PM
local boy's Avatar
local boy
local boy is offline
Sraight Axle Swap
Hello, I am building the big kahuna (My Wife) a '94 Bronco. I will be swapping out the TTB for a Dana44 Straight front axle. So far I have a 9" skyjacker lift for a '78 '79, james duff radius arms, and 38x15.5x15 SSR's on 15x12 rims. All I need is Brake lines, shocks and a straight axle 5 lug dana 44. If someone has already done this and could share some info it would be much appreciated. I live in centennial.
Old 02-26-2004, 09:39 PM
bubbaf250's Avatar
bubbaf250
bubbaf250 is offline
Try searching for "sas" or "axle swap" or "ttb swap" in the Big Bronco forum and in the Brakes, Steering, Suspension, Tires, Wheels forum. I know this topic has been discussed more than once in those forums.
You could also post your query in either the Big Bronco forum:
https://www.ford-trucks.com/forums/f...?s=&forumid=44
or in the B,S,S,T,W forum:
https://www.ford-trucks.com/forums/f...?s=&forumid=64
(Please don't cross-post in both forums at the same time though. It dilutes the responses and reduces the ultimate value of the technical content.)
Also, I know several guys in the 2Big Broncos club here in Colorado have done this swap. Some of them would probably be willing to help you with wrench turning, as well as advice/suggestions.
Check out my other post where I mentioned the club's web site:
https://www.ford-trucks.com/forums/s...hreadid=207550
Old 02-26-2004, 10:18 PM
local boy's Avatar
local boy
Thanks for the info bubba, sorry about the cross post I am not to computer savy. I had talked to anther Bronco owner and he said the guys at 2Big Broncos were a great group. Once again sorry for the cross and thanks.
Old 02-26-2004, 10:27 PM
mattri's Avatar
mattri
mattri is offline
Talk with Eric at Wild West Offroad. He is very knowledgable and very helpful. 303-806-8933
Radster
12-05-2016 01:20 PM
ZarK-eh
24
08-02-2015 12:28 PM
fordsford11
Washington Chapter
01-22-2012 12:41 AM
bigredtruck
03-14-2005 06:50 PM
SQUIGED
01-18-2005 02:36 PM
Quick Reply: Sraight Axle Swap
