Which motor oil weight do you use on a 351?
I recently purchased a ’96 Ford Bronco with the 351 engine. It has about 88,000 miles on it and runs really great. I want to change the oil on it but I’m undecided on what type to replace it with. According to the manual, the recommended weight is 5W-30 (at least that’s what I think I read) for the 351 engine. I’ve always used 10W-30 on my ’91 F-150, but then again, it’s only an inline 6. Do ya’ll agree with this recommended oil weight? What’s the most popular brand used? On my ’91, I’ve always used Quaker State and recently switched to the High Mileage type – it has about 180,000 miles on it.
I also have a slight concern with something I think may be coming from the transmission. At take off, I feel a slight jerk, almost as if someone tapped my bumper from behind. I also feel this when I’m slowing down and about to stop. Is this normal or should I be concerned? It performed flawlessly during the 250 mile trip home when I purchased it.
Thanks in advance for any input.
My 88 5.0 manual says to use 10-w30. It gets hotter then heck here too and I use 10-w40 in the summer. I used to use 20-w50 but if I let my truck set for a couple of days I hated to start it cold with that thick of an oil in it. Most engines in the 90's and up recomend 5w-30 because they are built a little tighter. If it were me I would just go by the manual.
If it were a lease vehicle, I would follow the recommended 5W30 because they foot the repair bills. Look at it this way...
5W30 is lighter/thinner- after warming up, it starts to thin out more. The hotter the oil gets, the faster it breaks down too. And when oil doesn't protect as it should, goes the motor! As we all know, engines don't like being HOT and lightly lubed!!
In this part of TX it gets HOTT in the summer, and not all that cold in the winter. 20W50 may be too thick for really cold winters, but going with the 3000mile oil change, you can always put 10W30 in for winter...
Like I mentioned before, it boosted my oil pressure too. I was using 5W30 and with my "loose" bearings I had 15-20psi at startup, dropping to 1-3psi hot. Now with the heavier stuff I have 30-35psi at startup and 10-15psi hot. So I know oil is circulating pretty well with the heavier weight oil.
Just my 2¢...
Just my 2¢...
I use Chevron Delo 15W-40 all year in Southern California. Temperatures here range from the upper teens here in the mountains right now to over 100 down in the desert in summer. 15W-40 is heavy duty "fleet" oil sold in gallons for diesel and gas trucks. It has more detergent/dispersant and ZDDP anti-wear additive than passenger car oil. Pennzoil LongLife, Shell Rotella T and Mobil Delvac are other popular fleet oils.
Jim
Jim
Jim
Jim
Ape-louise
08-22-2014 01:59 PM
sledhead999
12-05-2002 05:47 PM
