Good way to re-use an old chest freezer.
So I had an old 10 cu. ft. chest freezer in my garage that I picked up almost a year ago because it was "free for the removal". I won't fall for that again. I lugged a circa-1950 freezer (*very* heavy) out of my future brother-in-law's basement. I finally plugged it in and ... it didn't work. My neighbor is an HVAC tech & he figures it lost the freon charge. Faced with the prospect of loading it back in the van (it hasn't grown any lighter) to haul it to the recycling yard & reclaim some space in my garage, I hit on an alternate plan.
I have a problem with moisture from the air condensing on my tools & rusting them every spring. Because of the nature of my garage (the maple tree is slowly succeeding in pushing the garage over), I can't really do anything about the moisture. I needed a climate-controlled cabinet to store the more sensitive tools in.
So... I screwed some casters to one end of the freezer & stood it on end so the lid opens like a door. After I released the latch & the lid nearly smacked me in the face, I removed the balance springs from the hinges. I hung a couple of old refrigerator shelves (I have a problem throwing out stuff that *might* be useful for *something*) inside and mounted a lamp socket parallel to one of the lower inner panels. I put a 25W piano-lamp style bulb in the socket & plugged it in. The interior of the freezer-***-warmer seems to be hovering around 50-60F when the ambient temperature is around freezing.
So long as the temperature in the freezer is above the outside temperature, I will not get any condensation on the tools (or inside the power tools). And it's surprisingly deep - deep enough to store a sawzall in its case.
I love this kind of solution - no more damp tools, the non-steel parts don't get burned up in a steel mill, and no strained back hauling the thing away. It looks kinda cool, too.
A co-worker suggested I paint it red & put a Snap-Off sticker on it.
Cheers,
Eric
Cheers,
Eric
I had never thought of it before, nor had I heard about it, so I thought it was an original idea. Sighhhhhhh...
Thinking about it though, the freezer has a couple of advantages over a fridge: 1) It's deeper than a fridge, so it'll hold bigger stuff, and 2) It isn't divided into two sections (fridge & freezer). This freezer also has textured aluminum inner panels, so it should prove more durable than a plastic-lined fridge.
A fridge, of course has the advantage that it already has shelves in it.
It's still a pretty neat idea, though.
Cheers,
Eric
Cheers,
Eric
I had an old freezer that I used as a riding mower repair station. I was able to change the belts, add a mulching attachment and replace the blade with out working on my old knees, I should have kept it for the uses previously mentioned. My current one will be used a psuedo-temporary lockable tool cabinet/gun safe. But it has to quit working first, and I hope I don't have it full of beef when it does.
