What is a swing bearing?
>what does it have to do with or where is it located? never
>heard of a swing brg but sometimes people use a slang term
>instead of the "propper" ford term.
My motorhome has a carrier bearing.which is a bearing mounted
on the cross member between the 2 piece drive shaft.
never heard it called a swing bearing though
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Rich
not with rocks
Maybe I'm just older or maybe it's locale (SE Texas). I started in the auto parts business back in the 60's.
Swing bearing was commonly used to refer to the driveshaft support bearing or carrier bearing. Carrier bearing may be a misnomer since carrier bearing normally refers to the side bearings in a differential.
Mike
Mike
If the bearing you're referring to is the the bearing that supports a two piece drive shaft, here in Saskatchewan, Canada, we refer to it as a center bearing. I used to have to change these things on my '89 F250HD SC LB 4X4 like oil. Any mud + water and it would be shot, got really annoying at $50-60 a pop.
Never heard of it referred to as a swing bearing, so I may be way off base.
Waxy
Waxy
Hey waxy ! were you using oem or aftermarket replacements!
reason i ask is the spicer aftermarkets are sealed an have a grease fitting on them now!
Yea ! carrier or center bearings is problably what this guy is talking about
Later
Rich
not with rocks
Later
Rich
not with rocks
