First Waxing, Any Suggestions
Not an expert by any means, but I do suggest that you "Claybar" the entire truck before any wax application. the claybar will remove any contaminants so they wont get sealed in under the wax.
products?
I hear Zaino stuff is excellent!
http://www.zainostore.com/Merchant2/merchant.mvc
Also like Joe said above...Adams polishes are good stuff too! I have seen some of Joe's detailing work, and armed with Adams...its rocks!
products?
No it wont, when using the claybar you also use a lubricant like a quick detail type of spray, so it picks up the crud and will not scratch the paint....assuming its not big chunks of dirt!
wash the truck real good, then after it dries "Feel" the surface
then claybar a small section, and feel the difference! its amazing stuff! After you do a section, work the clay (knead it) so a fresh spot is used for the next section.
claybar also works well for removing paint overspray!
