1995 Ford Van overheating but blowing cold air!?!
on
1 Post
My dad has a 1995 Ford Van with a 3.8 L V6. It's a Ford van but not an Aerostar. It's the other one that's not based on a truck platform!
Anyways, he was driving down the road the other day and noticed that it was not blowing hot air, let alone warm air. He looked at his temperature gauge and it was reading hot. This was just as he was pulling into his driveway. He parked it and has not since drove it.
We haven't looked at it yet but are trying to figure out the problem before we tear into it. If it was the thermostat stuck closed would it not blow hot air? Let me know if you have any ideas.
-Matt
-Matt
Two things come to mind. I see that you are living in Canada and assume that the ambient temperature was real low.
1. Not enough anti-freeze and radiator froze up. When this happens you don't have any coolant flow through the engine and it will overheat. Solution - use a higher concentration of anti-freeze.
2. Water pump not pumping. Solution - change water pump.
on
1 Post
-Matt
I think you missed my point on the anti-freeze. I'm not talking about the fullness of your radiator but the anti-freeze to water ratio. If you don't have enough anit-freeze to water in cold cold cold weather your radiator will freeze. When this happens you will blow cold air out the heater and show an overheating engine at the same time. My guess is that is what happened. As far as your question about the pump not pumping after weeping for awhile I really don't know. I've only replaced one water pump in the last 32 years.
I don't know the specifics of your van's heating system, but along with the possible problems already listed you may have a switch problem. I've had a problem with my truck heat not warming up when the switch to let engine water through the heater core doesn't open up.
If your van has a switch (vacuum or electrically controlled) to let water circulate through the heater core make sure it's working properly along with the other things already mentioned.
ok u guys talking about like a heater control valve or switch.
think i got the same kind of problem, heat not up to where it should be. works fine in town but when i hit the highway it gets cold. that is if i stay under 55 its fine but 60 and above temp gauge drops like sticking theromostat, so replaced twice still had same problem.
A 1995 Ford van that's not an Aerostar and has a 3.8L engine in it, with the problems you have, probably needs new head gaskets.
It's a very common problem
The head gaskets leak, air gets into the cooling system, the engine overheats but there is air in the heater so you get no heat out of it.
The car that your van is based on also has the same problems regularly.
How many km's on the van? Ford extended the warranty on the head gaskets on these but I'm not sure what the coverage is. You might want to check with your dealer and see if they can do anything for you.
on
1 Post
Well, I think I narrowed it down. The rad coolant was full and not frozen. I started the van and let it run for 15 minutes. It was throwing out a lot of heat. The heater core hoses were hot. The engine to rad hoses didn't even get warm. So I am thinking thermostat. After the van was running for 10 minutes I slowly STARTED to open the rad cap and anti-freeze started spewing out. SO that means my water pump is good because coolant is circulating right? I think the water pump is shot though because I have a leak on the passengers' side of the engine and it looks like it's coming from the A/C compressor but I think it's the waterpump leaking fromt the weep hole and running down.
Any other ideas or recommendations? Let me know.
Should I just do to Ford to get a thermostat? I get a discount there.
-Matt
-Matt
on
1 Post
Well, my dad and I are going to change the waterpump tomorrow. I think that may be the problem. I also think it is leaking anyways. I am also going to change the thermostat as well. Anything else anyone recommend's that I do at the same time? Or anything I should look out for? Thanks
-Matt
-Matt
on
1 Post
Well, the problem is BACK! My parents haven't been driving the van all winter because it started doing it at the beginning of the winter. Van gets hot (on temp gauge) and there is no heat coming out of vents.
Last winter a shop changed the water pump, thermostat and timing chain (just because they were in there). My parents drove the van all summer with no problems then it got cold and they started again.
So, what should we look for? What else would be the symptons of a bad headgasket? Coolant in oil? I am pretty sure there isn't any. Anything else? Ideas?
-Matt
-Matt
Received 3,115 Likes
on
Matt, it almost sounds like the impeller in the water pump in not properly attached to the shaft. when it is cold, it works properly, but as the engine heats up, the impeller expands, and then is no longer attached to the pump shaft, and no longer pumps water.
i know this is a long shot, and i have never seen it on a ford pump. but i have seen it on 4 or 5 Chevy pumps, and they were all rebuilt pumps.
