1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
4.0 V-6 Exhaust Manifold Bolt Torque Specs
Old 12-28-2003, 07:05 PM
swampdog2002's Avatar
swampdog2002
swampdog2002 is offline
Hello all,
I recently replaced an exhaust manifold gasket on my 1994 Ford Ranger equipped w/ a 4.0 L V-6, and am in need of the torque specifications for the six (6) manifold bolts. Is there an online service manual somewhere where I can access this information? Any information would be greatly appreciated. Thank you.
Old 12-28-2003, 07:16 PM
84ford460's Avatar
84ford460
84ford460 is offline
Tighten in two steps.
1) tighten to 15-22 ft lbs.
2) then tighten to 52-59 ft lbs.
I'd run it for awhile and then retorque.
Larry
1996 Ranger 4x4
Old 12-28-2003, 07:19 PM
84ford460's Avatar
84ford460
swampdog , I screwed up!
I gave you specs on a 3.0L
Here is the right ones:
1) torque to 20 ft lbs.
Old 12-28-2003, 07:54 PM
swampdog2002
Thanks so much! I noticed an exhaust leak the other day from the left side manifold, and was surprised to see that there was no gasket in place after pulling the manifold. The same is true for the right side. I didn't think that it was possible to achieve a metal-to-metal contact seal on exhaust manifolds, but the factory did this. Interesting. Thanks again!
Old 12-28-2003, 07:57 PM
84ford460's Avatar
84ford460
Yeah,
I worked on a friends Dodge that was like that. No gaskets just machine fit.
Larry
Pollack Pete
1997 - 2003 F150
11-23-2023 09:35 PM
whale15
05-16-2015 06:22 PM
fusioncom
06-30-2006 08:52 AM
Smokejet
Exhaust Systems
07-30-2004 05:39 PM
Quick Reply: 4.0 V-6 Exhaust Manifold Bolt Torque Specs
