1001 uses for Zip Ties
Old 07-10-2002, 07:00 AM
TallPaul's Avatar
TallPaul
TallPaul is offline
Ok, we've all seen 1001 uses for Duct Tape, everything from covering rust holes in your truck to making the cat walk funny, and we know there are over 1001 uses for WD-40 (I believe Henry Ford would have used the stuff for hair spray). Now list all your uses for Zip Ties. I'll start,
Fix dishwasher rack
Key ring
Bicycle spoke clackers
Hold parking brake cable to frame until get repair part
Fasten kids bicycle name plates
Fasten hanging plant to awning support
Old 07-10-2002, 08:29 AM
HotWhlz85's Avatar
HotWhlz85
HotWhlz85 is offline
Ok, the obvious first;
Tying wiring or cables together
Handcuffs (best left to the cops)
Securing loose objects (either permanently or temporarily, insert name of favorite loose objects here)
Not so obvious;
Dog choke collar (only works once per dog)
body piercings (remember rubber bands?)
hinges for a swinging door/gate
loops for hanging tools, fishing rods, etc out of the way in the garage
That's all I can think of right now, but 1001 uses is probably just scratching the surface.
Ron
Old 07-10-2002, 08:41 AM
TheWiz427's Avatar
TheWiz427
TheWiz427 is offline
Hmmmm let's see
Fasten dryer vent to dryer
Straping the coax to the side of my tower
Tieing up the loose wires under the dash
Holding up a bumper till i could get it fixed
Ocasionaly use them as trash bag ties (only as last resort)
Holding up Christmas decorations
Hanging the beware of dog sign on my fence
Just to name a few
Wiz
An Equal Opportunity Truck Lover!
http://www.clubfte.com/users/thewiz427/index.html
Old 07-10-2002, 08:59 AM
theologian's Avatar
theologian
theologian is offline
Great for attaching tactical slings to the forends of Carbines.
depth stops on drill bits.
splints for sick trees.
Securing broken posthesis.
Adapting Truck seats to fit accurately on the frame of electric wheelchairs (done it, lasted for over a year no problem)
Balancing ceiling fans.
using as a pick to scrape bits out of the actions of pistols.
using as a rough and ready gun lock. (does keep tots safe)
Plus all of the obvious ones.. That is all i can think of in the few minutes I had spare, Maybe I can think of some more later.
Wm
'96 F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhaust,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb 4 wheel drive, 4.10 gears, 12,ooo# winch
Old 07-10-2002, 11:25 AM
alanscott's Avatar
alanscott
alanscott is offline
Sheep herders use them for castration. Ouch
Old 07-10-2002, 11:59 AM
1970f2504x4's Avatar
1970f2504x4
1970f2504x4 is offline
Aside from all the obvious ones:
Practical Joke - Place a big ol' zip tie on the drive shaft of someone's car or truck. "Do you hear that noise??"
James Kern
1970 F250 4x4
Old 07-10-2002, 04:50 PM
TorqueKing's Avatar
TorqueKing
TorqueKing is offline
I can't add any unique uses to this board, but I will second the notion that they are most certainly on the list of fine products that will always adorn my garage!
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old 07-10-2002, 04:57 PM
wolfmanagh's Avatar
wolfmanagh
wolfmanagh is offline
Toothpicks
I've seem someone use them to hold the straps on their overalls
I doubt there is as many uses as the "handy mans secret weapon" duck tape.
Old 07-10-2002, 07:45 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
holding the grille in on a 79 F-150
keeping loose wires hidden under the dash
used in place of a small bolt to hold the coolant recovery tank in place (previous owner's work)
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old 07-10-2002, 10:18 PM
STR8 SIX's Avatar
STR8 SIX
STR8 SIX is offline
-hold 2 piece fishing rods together
-Pant gaters....holds my jean pant legs down when I put on my chest waders
I have used duct tape for the gater part as well
-used to hold a flapper onto the exhaust of a friend's tractor....had to replace often
-Hand cuffed my niece just cuz she did not believe I would do it. She was stuck for about 30 seconds till the whining became unbearable
-makes our lawnmower keep running even when you let go of the bar
-ditto with the snow blower
That is all I can think of now....
Old 07-10-2002, 10:45 PM
canadianfordman's Avatar
canadianfordman
canadianfordman is offline
I use one instead of a key for my trailer hitch pin, saves someone walking buy to steal it unless they have a knife, and its much cheaper then the lock.
I also use one to hold all my other ones together, ehh Hows the for impressive.
Old 07-11-2002, 05:56 AM
BrettCox's Avatar
BrettCox
BrettCox is offline
King Triton
09-04-2004 04:16 PM
77redf250
13
03-15-2004 06:25 AM
Vampiro
10-15-2002 05:08 PM
Quick Reply: 1001 uses for Zip Ties
