SOHC V6 Oil Pump Change
Old 12-20-2003, 07:31 AM
Night_Mayor's Avatar
Night_Mayor
Night_Mayor is offline
Can I do this without removing the engine?
BTW Its insane to design something like this(have no Oil pan and putting the crank case inforcement thing over the *#%^@*$ Oil pump).
Old 12-30-2003, 06:09 PM
hreed's Avatar
hreed
hreed is offline
I tried it on my 2.8. The manual says it can be done by jacking the engine up at the mounts with a 2x4. Don't believe them. If you are persistent you can get the pump off, but will not get it back on. Plus, the oil pan gasket is nearly impossible to get back on that way. I know it sounds like a lot of work, but pulling the engine is a better option.
Old 02-10-2004, 10:22 AM
GizmosStang's Avatar
GizmosStang
GizmosStang is offline
WHEN THE MANUAL SAYS THIS IS A VERY DIFFICULT TASK REQUIRING SEVERAL SPECIAL TOOLS AND REMOVAL OF THE ENGINE FROM THE VEHICLE...
You should back away close hood and scrap it...
Nothing on the 4.0L SOHC can be accomplished in the truck if you have to remove that sorry excuse for a oil holder on the bottom end you will have the engine out it will leak oil for the rest of its life...
Its far easier to pull it do what you need to do and put it back in than attempt anything in the tight quarters under it.
Old 07-17-2019, 08:22 PM
Dmalon57's Avatar
Dmalon57
Dmalon57 is offline
Yes, however on my 4.0 4x4 I did have to drop the front differential to remove the upper oil pan (ladder)
chukar
07-19-2017 02:37 PM
Rollingscrapmetal
06-22-2017 08:40 AM
gwalker12
05-23-2017 09:09 AM
Harley Hill
11-11-2016 11:25 AM
Damifiknow
10-02-2016 08:24 PM
Quick Reply: SOHC V6 Oil Pump Change
