1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
'92 Ranger with trouble code 222
Old 11-29-2003, 06:07 PM
Sundevil Brett's Avatar
Sundevil Brett
Sundevil Brett is offline
My '92 2.3L Ranger is having intermittent problems. The only thing that seem consistent is the 222 trouble code. If I clear the codes, drive it and test it again sometimes it goes away but then it comes back later. I also have a lot of trouble with it stalling out, usually between 1-2 or 2-3 shifts, but sometimes cruising in 5th. I also have troubles getting it started when it is cold.
Recently I replaced the plugs and wires and had the resistance in the coils tested. Today I replaced the ignition module (not cheap). I still am having some stalling problems. It feels like fuel at times but the code points to ignition.
Any thoughts on the problem? I am about out of ideas!! Thanks.
Old 11-29-2003, 08:49 PM
Ken00's Avatar
Ken00
Ken00 is offline
I would start by running the pinpoint test for the code, if you don't have I should be able to email it to you.
Old 11-29-2003, 08:54 PM
Sundevil Brett
Please do
I would love to try the tests. Please email whatever you have to dcarlson93@msn.com
Old 11-29-2003, 09:18 PM
Ken00's Avatar
Ken00
Ken00 is offline
I tried to drop you an email through the FTE system but you don't have it turned on, please enable it so I can contact you. You can't post email addresses in the forums.
Old 11-29-2003, 09:38 PM
Sundevil Brett
Sorry
Sorry about that, please try again when you have a chance. Thanks again
Brett
2046fan
34
01-26-2018 12:43 PM
SHOpar
Vehicles for Sale
07-17-2016 02:29 PM
mattmesa
17
06-10-2012 02:19 AM
Mhzjunkie
06-12-2006 10:58 PM
Sundevil Brett
12-05-2003 07:06 PM
Quick Reply: '92 Ranger with trouble code 222
