Arizona Chapter Join Chapter, Leader:
head light assembly on 1993 f 150
Old 11-28-2003, 11:26 PM
tomfords's Avatar
tomfords
tomfords is offline
Question head light assembly on 1993 f 150
How do you remove a 1993 f 150 headlight assembly? Unlike the newer headlights there are no tabs but phillip screw heads that do not turn..
Old 01-20-2004, 09:34 PM
bosshoss's Avatar
bosshoss
bosshoss is offline
If i remember, first remove the two cross point screws on top of the headlight grill assy. Then remove the two 10mm nuts on the backside of the headlight assy. They are hard to get to sometimes. One is in the corner. If you are removeing the right head light, you need to remove the battery and the tray i think. its been awhile. Good luck. DP in NC.
texas_tech_guy83
Electrical Systems/Wiring
13
08-14-2021 12:27 PM
julieta
06-26-2007 02:38 AM
bobby d
12-05-2004 07:36 AM
Rockstar
04-03-2002 11:16 AM
Rockstar
Paint & Bodywork
03-29-2002 06:40 AM
Quick Reply: head light assembly on 1993 f 150
