87 302..Smog, Exhaust holes in back of heads
I have 87 302 5.0...I took all the smog stuff off...in the back of the heads there was a exhuast toob coming from each head ..I took those off,cut the toob then welded it together...now i have a leek from one side..My ? is does anyone know the best way to fix this...can't i just take a pipe threaded bolt and plug it with that ...and if so does anyone know what sizt it is? and I can't find it at the ford dealership..
Thanks Tattoo Matt
Thanks Tattoo Matt
Stop by any good head and block shop and ask them. I don't know the exact name of it but it will thread in almost like a helicoil to block the hole and will have threads on the inside to bolt your accessories in. They should know what you are talking about and if you ask real nice will probably just give you a couple
Clint
Clint
I think he means the accessories on the front. But that won't be necessary since your working on the rear of the heads.
He is right about going to a machine shop though. You can also go to your local dealer and get them. They are called thermactor port plugs, they only cost a couple bucks.
FORD-or-Die
02-08-2017 11:38 AM
danger-ranger93
23
07-16-2011 01:41 PM
