Transmission ID Codes
I have a 1990 F150 4X4 with an AOD transmission, door code K. I have a 1988 F150 4X4 for parts with an AOD?, door code K. I assume this is the original transmission in this truck. I need a transmission. according to the selector letters, my 1990 has the PRNDD1 and the 1988 has PRND21. will this mean that the 1988 has a 3 speed with no OD?
Any help is good help.
Dan
Dan
I'm no expert on parts compatibility, but here's a partial list of what you might run into:
Tranny crossmember problems
Drive shaft lengths - front & rear
Tranny/TC bolt up problems - not sure if they're compatible.
The good news is that neither tranny is computer controlled, so you won't have to dig too deeply into the electronics side.
Also keep in mind that your gas mileage will drop noticably because the C6 has no overdrive. However, the C6 is a much more reliable transmission than the AOD.
Michael W Cowles
03-25-2016 09:53 PM
vouvray
01-28-2003 02:48 PM
